Openbox S10 v Dreambox 800HD Pro
  • DLINKLA
    • 128
    I am after some advice on the above two boxes.
    Basically I am after a box that connects to cccam client. Nothing fancy just so I can use it with a motorised dish , it can pick HD channels up and picks up all available satellites
    Im not technically gifted so setting up images and software is going to prove a little difficult but I'll try.
    Can people please tell me what problems thu have cone across with both boxes
    What are the pros & cons of each box
  • stewiebee
    • Jun 2011
    • 68
    I own both openbox easy to setup but truly awful epg.dreambox better but more knowledge needed to setup but good 7 day epg great hd picture,for me the dreambox is best.
    • mdt
      • 3034
      i also own both and its the dm800pro all day long for me although they can be very frustrating at times. regards mdt
      • DLINKLA
        • 128
        I'm just after a box that is easy to update than can connect to cccam
        Picture is good and can work my motor
        Programme guides are not important to me
        Just something that i will be able to use for a while.
        Updating a dreambox seems quite complicated I don't want to "brick" my box before I've even used it.
        I've seen some dreamboxes on eBay and they say they will update the image before sending and what picture do I want ?
        To be honest no idea
        So confused
        • mdt
          • 3034
          So confused
          images are usually a personal choice as there are a few good ones around but as long as you choose a image for your sim/ssl type you will be fine and you can get all the help you need on here. the latest dm800 images have all the addons like tspanel ect included so its just a case of entering your lat/long details ,config file and and downloading a channel list and your done. regards mdt
          • DLINKLA
            • 128
            The downloading of a channel list is done when I scan for satellites is that right ?
            Does this box need a null cable or can everything be down via USB ?
            I keep changing my mind from s10 easy to set up or dreambox better value for money
            • andy91
              • 3583
              Takes me 20 minutes to flash a box,Set up network,set up tuner for usals and add long and lat.download Cccam,install bouquet,set up better remote with Pauli Neurtino and add the thing we cant talk about
              All on a Dreambox 800hd Pro you wont be sorry.
              Andy.
              • DLINKLA
                • 128
                I have found a few sites selling the box and some on eBay who say they will load the image
                DREAMBOX DM800HD SATELLITE RECEIVER - SIM 2.01 / Rev M Tuner / BootLoader 76C
                DM 800 HD PVR, Dreambox 800S Satellite Receiver(Pro)
                DM800HD (PRO) SAT RECEIVER (M) BSBE2-801A WITH SSL82 BOOTLOADER NEW SIM 2.10 - ukdreamshop
                Are any of these any good
                • andy91
                  • 3583
                  Just paid 115 quid from Yaoxin through Tina,box took 4 days to come from China,its a no brainer.
                  Andy.
                  • DLINKLA
                    • 128
                    I've been recommended them today , ill will go on there website now
                    How often does this box need updating ?
                    • andy91
                      • 3583
                      If your talking about bouquets,i change when i feel the need which is about once a month if lucky.
                      Frequencies change a bit but not always the popular channels.
                      These boxes are not plug and play but once you get your teeth into it they are pretty simple.
                      All the answers are on the forum and if you get stuck just post.
                      Just be weary we cant talk openly on the forum but we can via pm
                      Andy.
                      • saj1985
                        • 785
                        Andy.
                        you been timing yourself with a stopwatch?
                        is setting up a dm800 similar to setting up a dm500?
                        Dreambox 800hd se/Dreambox 500s, 90cm Solid Dish, Tm2600 Motor, TM-1 Gold LNB!
                        • mark8393
                          • 2305
                          yes not much difference, but i can do it faster than 20
                          • mark8393
                            • 2305
                            if you want something simple to use, go blade bm7000hd, or if you have the ability go dm800. blade are piece off piss, all done via usb
                            • andy91
                              • 3583
                              I wasnt bragging how fast i could do a box was merely pointing out how quickly a box could be set up.
                              You could probably do it in 10 minutes without all the booting between downloads etc if you know what you're doing.
                              Dreambox 500 is similar but flashing is normally done with Dreamup and null modem cable.
                              Would choose Dreambox over most boxes due to the support on the forums.
                              Andy.
