Digit Transponders 1w
  • Andreas
    • 4
    Hi there, first post on this forum.
    I have just set up my motorized system together with using diablo 2.3 for the footie. Searched for Canal sport channels and openned them no problem, but i cannot get good enough quality readings for the digi package channels (nova sport czeh, prima sport, etc), despite the signal strength being pretty decent 90%-95%.
    The system seems to be set up correctly on the arch as i receive other satellites.
    Any ideass?
  • Curious123
    • 2591
    Try this on your box;
    Menu > Setup > tansponders and satellite > transponder Edit > Scroll down till you find 1.0W Thor > Ok > change orbital position from 10 to 8 > Save.
    • .: JaCkPoT :.
      Retired Sat TV Addict
      • 5611
      Canal is on 0.8west and digitv is 1west.. Why not change the settings to 0.9 instead to get the best of both worlds
      ___________________
      In the good old days, I had
      DM800s HD
      Openbox S10
      TM500
      DM500s
      90cm FortecStar dish
      Maxx 110cm Dish
      Technomate 2300 Motors
      • Andreas
        • 4
        The 0.8w is not listed on my technomate box, do i need them set as 2 separare satellites? I presume my 90cm dish in Cheshire is ok?
        Could this be a lnb frequency issue, as i can pick up all transponders up to 11.750 but none above? The lnb is set on universial freq 9.750 / 10.750.
        Thanks in advance...
        • .: JaCkPoT :.
          • 5611
          No..the two sats are merged into to one and classed as one..
          90 cm is fine
          ___________________
          DM800s HD
          Openbox S10
          TM500
          DM500s
          Maxx 110cm Dish
          • Andreas
            • 4
            Cheers for the info. I will try and fine tune 1w tomorrow.
            I take it a universal lnb should pick up all transponders needed?
            • .: JaCkPoT :.
              • 5611
              Yeah..will definately
              ___________________
              DM800s HD
              Openbox S10
              TM500
              DM500s
              Maxx 110cm Dish
