Hi guys i am on a motorised system everything is fine but when i go on 19.2 deg east i have an 85% signal and 75% agr, after about 3 mins i lose the signal completely. Is this the lnb or what i have tried to move the dish with the motor setup but cannot get it to lock any help here would be appreciated thanks guys. Just to add it seems to be fine on all the other sats.
WHY AM I LOSING SIGNAL... IS IT THE LNB
If it's fine on all other sat's m8 it's not the lnb!!!..it seem's that the dish is out of whack on that one sat..don't know what receiver you have m8 but you'll have to tweak the dish up and store it [when you find it that is]..come back with a little more detail's and i'm sure someone will be able to help you out..
regard's
terry. -
heres what i would do mate turn it to 0.8w check the signal if you can better it then it confirms the dish is slightly out
to resolve this without leaving your armchair you can adjust the longitude so if its set at 001.700 change it to 001.800 keep changing it then check signal once you get it at its best try other sats
dont forget the thanks button
make sure your f connectors are on tight and connected properly,Hi guys i am on a motorised system everything is fine but when i go on 19.2 deg east i have an 85% signal and 75% agr, after about 3 mins i lose the signal completely. Is this the lnb or what i have tried to move the dish with the motor setup but cannot get it to lock any help here would be appreciated thanks guys. Just to add it seems to be fine on all the other sats.
ensure there is enough flex on coax wire for when the dish/motor move.Dreambox 800hd se/Dreambox 500s, 90cm Solid Dish, Tm2600 Motor, TM-1 Gold LNB!
