VU+ DUO or XTREND ET9000 OR TECHNOMATE 7102 HD - PLEASE HELP!
  • satlover276
    • Oct 2011
    • 95
    I am new....
  • cactikid
    • 12017
    as i said xtrend ,i wonder if the mods will read this as one of them got the xtrend.might be able to give your more info,be carefull about the cardshare info,its taboo over here.
    • satlover276
      • Oct 2011
      • 95
      thank you again for
      • cactikid
        • 12017
        i am in the middle of change over from dongle in the intellinet 3g mobile broadband router 300n 3g router as mine glitches and freezes and light goes out ,i dont know if people here would use a dongle for whats involved,hopefully others can ,i presume you are in uk.
        • satlover276
          • Oct 2011
          • 95
          [quote=cactikid;1294856]i am in the middle of
          • cactikid
            • 12017
            i am not recommending my router ,it was that or vodafone,different country i am in,it will be people in uk would have to answer that one m8.wait for more answers before taking the plunge.
            • C64
              • 2394
              If you don't need a twin tuner machine then save yourself a fortune and grab a clone DM800SE, it'll do everything you need and you'll not find a better supported machine anywhere else.
              • satlover276
                • Oct 2011
                • 95
                oh ok..thank you
                • satlover276
                  • Oct 2011
                  • 95
                  i do need a twin tuner machine
                  • C64
                    • 2394
                    Originally posted by satlover276
                    i do need a twin tuner machine to be honest...but what's the quality of the picture on your machine like because i really am looking for the best in both HD and SD and it must also allow me to run c/lines from 2 different providers at the same time...
                    Dreambox 800SE has an immaculate image and it runs ccCam for your C lines, but currently it only supports a single tuner.
                    A multi-tuner is due to be released in November which will offer DVB-C/T/S all from a single tuner, also 2nd DVB-S2 support can be added via a usb tuner - although at this stage this is only a rumour.
                    • satlover276
                      • Oct 2011
                      • 95
                      thank you for your suggestion
                      • mdt
                        • 3034
                        sd quality on the duo is supposed to be awfull from what ive read but alot of it is personal opinion/tv being used/settings, although hd is great. 4 of the 5 channels are on the same txp, and only skai is on a different one so you could get away with a single tuner for recording and watching a different channel if you gave up skai in certain programme timing clashes. the duolabs q-box mini hd has twin tuners, runs on linux and can be bought for less than ?200. regards mdt
                        • satlover276
                          • Oct 2011
                          • 95
                          thank you. please let me know what
                          • flyingpig
                            • Aug 2009
                            • 930
                            Well I took the plunge and went for a Clarke Tech ET9000 with 500gb HDD - with the Vix image.
                            Fingers crossed it is as good as the reviews suggest.
                            • aftermath
                              • 4345
                              me too m8 got mine yesterday and took about 30 mins to set up.
                              nice stable box, and HD picture is excellent.
