I"ve just come across these as an f-plug replacement for outside connections,they are supposed to need no self amalgamating tape or other waterproofing.you simply slide them on the co-ax trim 15mm off the outer sleeve fold the screen and foil back trim the dialectric to about 3mm and cut the central wire to 9mm insert the central wire into the lnb or f-plug socket on the motor,slide the CAP F up and push it hard onto the socket trapping the screen/foil.I"v just redone one of my dishes and used them on the motor to see how they fare over the winter.they look fine for most LNBs as well but are not long enough for LNBs with long f-plug sockets such as found on invacom LNBs.
to remove simply unscrew
