ThomsonSky+ box
  • jimbob1953
    • 13
    ThomsonSky+ box
    Hi guys,I've got a sky+ box that willnot come out of standby,the red light just keeps flickering but stays on red, tried powering off and switching onagain at mains as well as holding in the buttons either side of select before switching mains on,seen this on some other help searches.Also disconnected hard drive but still no joy. Any one any ideas
    cheers jimbob
  • .: JaCkPoT :.
    Retired Sat TV Addict
    • 5607
    Is it under contract? If not you could try reloading the firmware from the pc if thats possible..
    ___________________
    In the good old days, I had
    DM800s HD
    Openbox S10
    TM500
    DM500s
    90cm FortecStar dish
    Maxx 110cm Dish
    Technomate 2300 Motors
    • jimbob1953
      • 13
      How do you get the firmware,box is not under warrenty
      jimbob
      • mark015
        • 254
        ok, this is wat u do..... read the guide through BEFORE u do it ok?
        turn on tv. NOT SKY
        turn off sky box at plug
        count to 10
        hold down BACKUP on THE BOX not the remote.
        WHILST HOLDING IN THE BACKUP BUTTON turn the plug for sky back on.
        keep it held in, then the tv screen should change (if u have it on scart it should, if on co-ax then you'll need to set your tv to the sky channel first)
        basically a black screen with white writing telling you that it is downloading update!
        it'll take 10-15 mins depending on how big the update is (downloading via dish!)
        once done the box will restart itself and you can see if your interactive stuff is back...(took from another forum worked for a friend of mines ,no harm in trying.)
        • jimbob1953
          • 13
          I gave that a go but red light just kept flickering,a couple of times it momentarily via scart tried to switch tv over onto satellite channel. Thinking that it may be the PSU and getting one of them repair kits where you change all the capacitors (?12 ebay). Anyone tried doing that that worked with similar problem.
          jimbob
          • jimbob1953
            • 13
            Fitted the capacitors replacement kit everything is now OK
            jimbob1953
