Motorised sat set up
  • gracieboo
    • Dec 2010
    • 368
    Hi there guys im going to being trying a motorised sat install for a friend at the weekend and this is my first timedoing motorised. The long and lat will be 54.5 and 6.4 west so my question is do i line up on 5 west as ref sat or do i use 1 west from here in northern ireland.mant thanks for any replys.
  • satsmo
    • 6397
    Without an exact grid reference I can only give you a rough guide. But going by your approximate long/lat 5W would be the best Sat to use.
    • gracieboo
      • Dec 2010
      • 368
      Thanks satsmo. Ain,t to sure what the grid ref is but location is portadown co armagh northern ireland bt63 5dh. Anyone from northern ireland feel free to give your input thanks.
      • alec
        • 345
        Your satb needs only one reference, to work out the rest.
        Just use the one that is easier for you, as long as you put the correct details in, and you know where to point the dish.
        • Nutsandbolts
          • Oct 2011
          • 1168
          Hi. Yeah from my experience it dont matter what your reference satellite is because USALS will know when to stop. In London i have used different satellites for reference point and always work. I take it you will be using USALS because if you use DISEC(1.2) your lat/long is not required. But obviously you need to make sure that you get the first satellite aligned spot on. Let us know if you need further help. Regards.
          • gracieboo
            • Dec 2010
            • 368
            Thanks for the reply guys but looks like i will maybe not be installing it after all as there is a lot of large trees blocking the road. it prob needs to go up quite a height to clear these and i think its a job for a pro. Pity thou i would have loved a crack at it.
            • Nutsandbolts
              • Oct 2011
              • 1168
              Hi. You can always do what i did. Before buying the motor i tried to find as many satellites as i could from ground level. I had the tv and receiver plus dish on the floor and manually found them. It took ages but was great fun and you learn a lot about satellites. Take care.
              • the goat
                • Mar 2010
                • 122
                i setup dish to look at 28e easy to find, had reciever and TV set up outside near dish on a workbench
                that way i could do slight adjustments easily
                then used USAL's and did slight tweaks to get them spot on
                its not hard, it took me on my own about hour to do,
                did have to go back and tweak 5e as origanally i could not decode their signal (if u know what i mean)
