Hi, recently sorted out a motorised dish and trying to get bullsat channels on my technomate 1500, have loaded latest softcam but they are not opening for me, i can get the voice on that sat and i have a good signal on other bullsat channels, am i doing something wrong? Thanks.
bullsat
Hi. If youre having problems with BULSAT channels it usually is ,apart from keys changing, to do with dish alignment. I had similar problems with getting some channels but not all. I had to slightly adjust the dish and LNB. Also check you have correct frequencies in receiver memory before you mess about with the dish. Regards.Comment
Hi. BULSAT frequencies as follows: 12.521H s/r 30000, 12687H s/r 30000, 12564H s/r 30000. Before messing about with the dish etc check if you have these frequencies in your receiver (in INSTALLATION MENU). If you dont have them manually put them in using PID SEARCH option in the INSTALLATION menu. Remember that the frequency and s/r must be accurate. Regards.Comment
Hi. also remember that you can look in your receiver manual for help. I have found the TM manuals to be quite good. What i do once a month is that i do a BLIND SEARCH on each satellite to check if any new channels appear. Regards.Comment
Hi. Welcome to the forum. What are trying to figure out?? Remember before you do anything make sure you read receiver manual, if you have one, to get to know your receiver capabilities. And you can always ask for info in this forum .Take care.Comment
