I can only get sic international on 12735 V 3702 at the moment on a TM.(cant try spider til tonight) I"m doing a blind search to see what else I can get.
yeah as well as the above I"ve got as active TPs
12.735V
11.063H
11.222H
11.232V
11368V
11518V
12616V
12652H
12677H
12684V
12733H
but digitalb/tring "no signal"
I believe that this has to do with the signal being chnged to W3C whatever that is, and the dish has got to be adjusted or something. Can someone please help me on this?
I have a TM1500 and a Spiderbox 9000HD and no signal on either of them from 16e
yeah they are playing about as you say but there are some channels you should still get ok try 12.677H2800 its an aljazeera test card but strong. or 11.220 H 30000 carli tv about the same strength as always. leave your dish on 16E or just try nudging a bit,king of sat says W3C is still moving.king of sat have a long list of whats on W3C but flysat list none so we will have to wait for the dust to settle I think.
ive just done a scan on a tm600 with todays upated satellites.xml file on a td110 dish in nw uk and got 74sd channels at 6.30gmt. sic int which is usually a strong txp with 90%ss/sq is at around 65%ss/sq but i havent ajusted my dish slightly and am using usals(54n/2.4w). regards mdt
