SuperJack v Technomate motor
  • DMBoot
    • Nov 2011
    • 114
    I bought a dish kit which included a Triax TD88 dish.
    I should have received a Technomate TM-2300 motor, but instead was sent a SuperJack DG-320.
    What are the merits of each motor and is it worth me kicking up a fuss to have the motor replaced?
    I've looked online at the prices of each and they seem quite similar, although the SuperJack doesn't seem that common?
    Any advice appreciated.
  • mikiemo
    • Oct 2008
    • 86
    make sure the motor fits on that dish,because superjack dg320 is for dishes 1meter to 1.2 meter diameter
    But it is a good heavy duty motor
    • DMBoot
      • Nov 2011
      • 114
      Thanks for that.
      By fitting on, do you mean that the U bolts for the dish are big enough to go around the arm on the motor?
      • mdt
        • 3034
        the motor should be ok as ive fitted one once with a 1m flaval dish and it went on ok. regards mdt
