Hi, this may be a stupid question but if i never ask ill never know. Can you use coaxial cable in both directions? Currently have a line coming from aerial on roof down to the room and into the tv. I have a TM 600 box which has an output which i would like to watch on other televisions in other rooms. What i was wondering is, can I send the tm 600 output up the same cable that the aerial signal comes down and split it in the roof space to enable other tvs to pick up the tm 600 output?
TV Out to all rooms
Tags: None
put the aerial into rf in on tm then the lead from your rf out into 2 way splitter one goes into tv then the other goes into loft space into a splitter will send tm600 picture + aerial signal.... check signal on aerial is strong enough to split if not you can use a powered splitter behind your tv...BJ1
you could use your aerial cable but you will lose your aerial then...bj1Last edited by bj1; 17 November, 2011, 00:16. -
