Sky remote
  • donkeyboy
    • 410
    Sky remote
    Hello
    My mums sky remote has stopped working
    I've changed the batteriers and done some quick guides to get to respond but no joy anyone got any idears before I buy a new one for her
    Cheers
    I may have a new one at home mate give a chance to get home and i will check for you and report back about 2.30ish.......................
    • dibble
      • Sep 2011
      • 24
      Originally posted by donkeyboy
      Hello
      Cheers
      If you have a PC with a webcam, set it so you get video from the webcam on your screen. Point the remote at the webcam and press a few puttons. If the remote is working you should see the remote flashing on the screen. The webcam picks up the IR from remote controls, which is invisible to eyes.
      Mama's got a Dreambox ...
        Is this the one if so pm me and its yours..............
        • donkeyboy
          • 410
          No m8 it's not
          Sky hd remote is what I need thanks though man
          @ dibble The remote works coz i checked on my camera everything lights up but doesn't respond to the reciver
          • Carew6
            • Mar 2010
            • 212
            Found this for resetting remotes , it might be worth a try.
            For most remotes Version 4 and later (white label inside battery cover)
            1 Press "TV"
            2 Press and hold "Select" and "Yellow" together until red led in remote end flashes twice (On HD remotes "Select" and "i" together) - if it doesn't flash twice then remote cannot be reprogrammed (clone or too old)
            3 Press "0" to operate standard box, "1" for Sky+ and on HD remotes "2" for HD - remotes in Sky+ mode will normally control HD boxes as well
            4 Press "Select" - red led should flash twice
            5 Press "Sky" and away you go
