spiderbox cccam giltchy
  • localhero
    • 231
    hi all, keeps freezing & crashes wat would be the nxt best box to get to stop this from happening if any??? thanxs all
  • mark36
    • 166
    Although the spider does have issues with cccam i'd be more inclined to look at your sealine first.
    check out your ecm times will give you an idea.
    Also the spider was less likely to perform well when using above cccam 213 although patches since suggest this has been fixed.
    I use one with a line with no real issues other than having to reboot after viewing FTA channels
    • Manic01
      • 5117
      Reload latest patch, shouldn't crash at all.
      Make sure your share is sound as well.
      • localhero
        • 231
        will try thanxs, i'm runing ethernet via a wireless router & not direct to modem would this cause it to happen!! just checked ecm 2277 hops1???
        • mark36
          • 166
          there's your answer ecms need to be really below 400 for stable viewing imo.
          with them as high as that you will never get good viewing
          • ramjet
            • 2995
            agree with mark , your ecm times are horrendous
            should be more like 100ms to 300ms , and 400ms is the limit on sly for instance
            yours is actually appalling
            • jon48
              • Apr 2010
              • 147
              ecms
              hello guys sorry for interupting how do u check your ecms?
              • Rodbouy
                • Jul 2010
                • 1320
                Press info on the remote control mate.
                As for the spider box and cccam there is nothing wrong with it at all.
                I have 3 family members with them for nearly 2 years and I find them great boxes and very very stable.
                If anyone gets problems still after a factory reset and and patch updates then its most likely their or the other end.
                Also prob the best and sharpest HD picture of any box I have seen or used.
                • ramjet
                  • 2995
                  press info TWICE !
                  • localhero
                    • 231
                    i think its a quality box thought i was or had done somthing wrong i.e ip was weak or probs as i've set it up via a wireless router, but on the whole a good easy box to use!! thanxs for all the info
                    • mark36
                      • 166
                      quite right mate
                      generally speaking its a good box
                      yes there's issues but on the whole as a plug /play box using cccam its pretty damm good,support on other issues well thats another story.
