Dish or lnb make model
  • robbeno
    • Feb 2010
    • 389
    Hi guys before I go & buy the cheapest dish on eBay, can someone tell me a good make or dosnt it matter, is it just the size tha matters
    Also the Lnb does this have to be a particular kind for better performance, I see them quad Lnb
    Are these of any good, there on fleabay cheap,
    Any advice guys Be appreciated
    Rob
  • Nutsandbolts
    • Oct 2011
    • 1168
    Hi. Get a 1 metre dish plus a motor and universal LNB. I get loads of satellites with my motor. Before buying anything always do a bit of research in forums like this one to get some idea of what is suitable for your tastes etc. Regards.
    • robbeno
      • Feb 2010
      • 389
      Yes thx bud is why I was asking, I was just thinking of a 60cm as I'm using a sad tiny old thing now, and it's glitching a little, a motorised 1 I'd love but just seems a Little to complicated for me. So if I was gonna get a static 60cm will any one do the job as good as any ?
      Rob
      • Nutsandbolts
        • Oct 2011
        • 1168
        Hi. It all depends on what you want to watch. With 60cm dish you will be able to pick up satellites like HOTBIRD, ASTRA ,FREESAT. Remember also that what you will be able to watch depends on what type of receiver you have. To be honest putting a motor on a 60cm dish is not that difficult but again it is only worth it if you have a patched receiver. Regards.
        • robbeno
          • Feb 2010
          • 389
          Yes I've seen motorised ones around ?80 on 60cm, I'm using a dm800
          But took me days to figure out how to sort the epg out on it I'm so not clued up, really would like 1 but installing it onto brickwork wouldn't be the problem, figuring it out prob drive me insane
          Might ask about and see who's got 1 installed and wots wot
          Cheers bud
          Rob
          • cactikid
            • 12017
            and dont pm me ,go look at the dm sat threads for plenty of info i would say m8.
            • ramjet
              • 2995
              I would suggest a triax dish of between 80cm and 110 cm , an inverto ultrablack lnb , and a superior or supreme darkmotor
              quad lnb,s give you 4 outputs for more than one box or a twin tuner box
              there are also twin lnb,s as well , including the invertos
              • robbeno
                • Feb 2010
                • 389
                Ha I had plans of you installing it for me cactikid
                • cactikid
                  • 12017
                  no worries i put mine on wrong side of building just to confuse everybody,ramjet offers great advise above,as cheap may have more problems.
                  • robbeno
                    • Feb 2010
                    • 389
                    I'm litterally up the wall m8, even the epg I've tried installing for days as jus dissapeared, box reebooted itself,
                    Its Just not meant to be , il end up throwing this on eBay soon and stickin with sv
                    • robbeno
                      • Feb 2010
                      • 389
                      Any offers in the Liverpool area to come around to mine and throw a motorised up get me up and going to get every satallite in the sky, and I pay well, even borrow me chic for a hour on top of wages
                      • Elric
                        V.I.P. soft lad
                        • 853
                        dont give up yet its not that bad,just a little time and paitient
                        • MrFug
                          • 880
                          Epg needs refreshed every X amount of days depending on how it's configured; sounds like yours is 24 hours.
                          The hardest thing about installing a motorised dish is the wall mount. Once you have it nice and vertical, the rest is straight forward.
                          For a professional installation, your looking at between ?300-?350 with equipment included.
                          • Nutsandbolts
                            • Oct 2011
                            • 1168
                            Hi. Dont waste 300 pounds or more to get a motor installed. Believe me installing a motor is not that difficult. i am not familiar with your receiver but check if it has USALS or DISEQC available. A brand new TM2600 motor cost 50 pounds new. Only problem is if you use a 60cm dish you will be restricted to only certain satellites. Best thing to do before buying a motor is to manually move the dish by hand and see how many satellites you are able to pickup from your location. Again you need to know how your receiver works when changing satellites, tuning transponders etc. Like i said installing a motor is not that difficult, you just need time and patience. I have installed more than 50 TM2600 motors in two years and they are all working fine. Regards.
                              Can we see pictures b4 we make a decision............
