hi all thinking about havin another sat box in another room. an openbox or a tm..
i have a motorised dish wat would i need to do this??
you will need a twin or quad lnb and run a second coax feed into your second room. your main box controls the dish and the second box watches the same sat the dish is pointing at. regards mdt
The answer that mtd give is probably the best way. However if you were only going to be watching one box at a time you could split the cable from the motor using a two way dc by pass splitter [they cost about 1.99 off fleabay] and add an extra cable run to your other reciever and that way both boxes can move the dish and watch whatever. BUT NEVER TURN THE TWO RECIEVERS ON AT THE SAME TIME AS A POWER SURGE COULD DAMAGE THE MOTOR. So if you are for turning the two boxes on at the same time opt for a twin or quad lnb as Mtd has said.
