protek 9710/9750/9760
  • dick b
    • Jun 2009
    • 2462
    Whats the exact difference between the protek 9750,9760,& 9710 (apart from visually)
  • Manic01
    • 5117
    Protek 9760 HD IP HDTV Sat Receiver
    A PVR ready (via USB HDD) HDTV and digital satellite receiver, with Ethernet port for IP services. Features a 1 smartcard reader, VFD front display and 10,000 channel capacity.
    Specifications
    - Digital & HDTV satellite receiver (DVB-S/S2)
    - VFD display
    - 10,000 channel capacity
    - Favourite channel lists
    - Electronic Programme Guide
    - Teletext and DVB subtitles
    - 1 x LAN/Ethernet Port RJ45 for automatic firmware upgrade over Internet and IP interaction
    - 1 x USB2.0 (PVR, software, channel lists)
    - YPbPr HD connection
    - HDMI up to 720p/1080i/576p @ 50Hz
    - 1x Smartcard reader
    - 1 x Scart
    - 1 x Analogue Video/Audio RCA
    - Component video and same time HDMI playout
    - DiSEqC 1.0, 1.2 & USALS
    - Loop-Through-Tuner
    - Dolby AC3 5.1 S/PDIF (optical) and Coaxial digital audio
    Protek 9710 HD IP
    ***8226; High Definition Satellite TV Receiver for European Digital TV Broadcasting
    ***8226; Fully Compliant with European Satellite Digital TV (DVB-S/DVB-S2) Standard
    ***8226; HD MPEG-4 AVC/H.264 HP@L4, MPEG-2 MP@HL & SD Video Decoding
    ***8226; Selectable HD Video output Resolution Format 1080i / 720p / 576p @50Hz
    ***8226; RF Input Range 950MHz ~ 2150MHz with High Sensitive Tuner
    ***8226; QPSK & 8PSK Broadcasting Signal Demodulation
    ***8226; High Speed 32bit RISC Microprocessor up to 266MHz
    ***8226; HDMI High Resolution Digital Video Interface for Digital TV set
    ***8226; YPbPr High Resolution Analog HD Video Output to RCA Connector
    ***8226; Scart connector for non HD TV Set
    ***8226; Dolby Digital(AC-3) 5.1-channel & MPEG Audio Decoding
    ***8226; Max 9,999 TV + 4,999 Radio Channel Memory Capacity
    ***8226; Fast Channel Searching & Fast Channel Change Switching Speed
    ***8226; Channel List & Favorite Channel List edit Programming
    ***8226; Quick Find function for finding desired Channel with just alphabet as channel name
    ***8226; HDMI/YPbPr Digital/Analog Simultaneous HD Video Output
    ***8226; High Resolution Full Color On-Screen Graphic Display
    ***8226; Optical S/PDIF Digital Audio Output for AV Receiver Amp RCA Cinch Analog Video(Composite) & stereo Audio output for TV or VCR
    ***8226; Electronic Program Guide(EPG) for on screen channel information
    ***8226; European Teletext & DVB Subtitle Display support
    ***8226; DiSEqC 1.0, 1.2 & USALS support for controlling LNB and motorized dish
    ***8226; 1-Slots Smart Card Interface for usage with Pay-TV-channels ( )
    ***8226; High Speed Software Upgrade Through USB 2.0 Host Interface
    ***8226; USB PVR Function Ready to external HDD(Hard Disk Drive) up to 4TByte
    ***8226; RJ45 Ethernet port
    • KryssToffer
      • Nov 2011
      Specifications
      - VFD display
      - 1 x Scart
      Protek 9710 HD IP
      Just got a 9760, spoilt for choice on what to watch Admittedly only been one day, but there is so much choice and the receiver seems to update itself, so once you're up and running, very little to do but sit back and work your way through the huge channel list!
      I looked at other options, but this box seemed to have, and so far does have, everything I wanted and more!
      Hope this helps!
      • longstack
        • Nov 2010
        how long does the gift last for
        • Manic01
          • 5117
          Older proteks now been turned off with a temp 6 months renewal for ?30. But will then basically finish.
          Protek have lasted around 5 years and been good boxes.
          How long the gift lasts on these new ones are anyones idea.
          Nothing is forever.
          • gracieboo
            • Dec 2010
            • 368
            Hi there all. When was the protek 9750 released as im thinking of getting one but just worried that if its been released a few years it will then be discontinued and i won,t get long out of the gift any replys greatly appreciated.
            • mdt
              • 3034
              best gift type recievers bar none!!! regards mdt
              • gracieboo
                • Dec 2010
                • 368
                Cheers any idea of the release year. If its 2009 say im thinking if the last gift lasted five years i could possibly get another three years if i purchased one. What do you think?Ive been told the team behind them are about the best around.
                • Mumus
                  • 8
                  Please can anyone explain to me what is meant by PVR ready? If I connect an external hard disk via USB, will I be able to watch a film? Does the 9760 have a media player? Thanks for any reply as I never used a reciever as a player.
                  Protek 9600 IP BT 1.34 SW T75 K67 working without ID
                  Maxx 10000 BT 1.34 SW T75 K67
                  Protek 9760HD_IP FW 1.13 HW 1.2 Key 0.1.98x
