JUST BOUGHT TRING CARD PLUS OFF E-BAY BUT THE CARD AT 3 PM JUST STAYS ON THE FILMS AND THE WILDLIFE I ASSUME I HAVE BEEN GIVEN JUST THE BASIC TRING CARD IS THIS WHAT HAPPENS AT 3PM FILMS STAY ON AND PLUS CARD FOOTBALL KICKS IN WITH THANKS
TRING CARD BEEN CONNED
yes , the one with the extra channels is tring sports ( in your case this is probably the plus card but needs activating ) , and even that plus card has been failing on a saturday recently for many users , plenty of posts about it all over the net
if you did view the channels you would also know it has a rolling banner at time stating its only to be used in the country of origin (albania) so if you are not in albania is hardly a con -
your supplier would have to check your entitlements and get activation codes sent over the air , whilst your box and card are receiving tring
then you would check if it works next saturday ( or check entitlements anyway )
if it fails next saturday , you do the same the following week , until your entitlements allow it to openComment
yours is set for standard and not plus m8
the info I gave you is what you need for 3pm sat matches as well as the others you are already getting
at least you now know what it should beComment
whatever the problem , you need to contact your supplier , or you could phone a shop and find out but those details are nothing to do with this or any other forum
I suggest you contact your supplier and said so in my first reply
it would appear that you dont have the correct entitlements , the card is probably correct , but not the activationsComment
I just wouldn't touch tring!
Regards.
Sat Boxes
Dreambox 500s.
Dishes
Sky minidish self fitted.Comment
I would imagine that is too cheap to be the card with the correct entitlements on it , and its the entitlements that count , NOT the card , as you found out
given that a decent box on its own costs more than that , I would be highly sceptical about it , AND you then become mentor , instructor , the person blamed when things go wrong
it never stops at just buying a box and , or a card , its the after sales support that becomes the hardest part , any little thing and they get on the phoneComment
