Hi. also dont forget to do a blind scan, if you have not already done so. The blind scan will pick up channels which are not already in the receiver memory. Good luck.
Help cant tune in my satellite,please help!!
HI. I dont know if your receiver has a blind scan option but usually you will find it in the INSTALLATION menu. Have a look and see or look in the receiver manual. Regards.Comment
Why the hell would he need to do a blindscan when all he needs to do is load the E1 channel list i posted dated 28/11 there may be a couple of changes but that list is pretty up to date and also has the latest sat.xml file as well.
Secondly do not confuse someone and telll them to do a blindscan on a receiver that is not even blindsan capable.
next time NutsandBolts i suggest you do a little research on the satellite receivers capability before posting a suggestion and confusing the OP.
