protek 9710 help
  • fastcar
    • 16
    protek 9710 help
    can somone tell me is there a list of wot is open on diffrent sats . thanks in advance
  • sambhi92
    • 293
    Google "protek online list".
    • dick b
      • Jun 2009
      • 2462
      here is a channel list for your box mate,load unzipped list onto usb stick formatted to fat32.go to system information and drop down to "load channel list from usb" after loading press ok then the blue button list of bouquets should now show pick one >ok click on a channel and it should open if not try another as although most are active not all are.
      • dick b
        • Jun 2009
        • 2462
        here is a list of what should be open on protek 97** boxes this is thanks to Boris T.(I havent checked them all but the ones I have are open)
        • fastcar
          • 16
          channel list
          thanks for that dick b, had grankids all weekend now time to play set up protek 9710 looped to spider 7000 tm motor, sats 30w to 53e
          • dick b
            • Jun 2009
            • 2462
            yeah its best to set up and fine tune your dish with the spiderbox as although the protek has a signal meter its not as good.the main sats for you will probably be 13E,16E,19E,and 23.5E,you can lock all the XXX channels so the kids cant get to them.
            • fastcar
              • 16
              channellist
              dish needed tweekin got all on 30 w but have got problem with channel list downlload . winrar say its corrupt wont let me load to usb .channels on 23.5 are not bad
              • dick b
                • Jun 2009
                • 2462
                hello mate just checked that channel list I uploaded and it is fine I opened with 7zip no probs and checked all the channels were there on a channel editor.If your using "internet explorer" that can cause problems and its not a rar file its zip.if you use firefox as your browser and 7zip I"m pretty sure it will open for you.
                • fastcar
                  • 16
                  your right dick b ive only ever downloaded files with winrar soory about that .
                  • redstje
                    • Feb 2012
                    learning
                    I am learning alot here,thanks
