Spiderbox blocked port
  • achillco
    • Oct 2011
    • 4
    Hi all, i face a problem since last week. I have the pvr nova card and when i share it to my 3 receivers(a spiderbox server + 2 other), after a short time it blocks me. I called nova and they unblock my card because they have sent an update and it blocked it. The other problem is that the port i have set on spider server , blocks after a few hours and it remains blocked. Does spiderbox have a default port that uses the gift? i'm despered with that receiver. any suggestions?
    Thank you in advance.
  • achillco
    • Oct 2011
    • 4
    When i reboot the spiderbox, everythimg is ok for a short time. Then the port is blocked!!!! What is going on .....? There is no firewall activated.........
    • Manic01
      • 5117
      change port to 12000
      • achillco
        • Oct 2011
        • 4
        Is this a default port for spiderbox? When my 2 other receivers connect on the spiderbox , the port blocks.
        • Geosat
          • Dec 2011
          • 4
          I have this same problem it's blocking port for no reason it's doing my nut in anyone any ideas does changing it to 12000 help?
          • ramjet
            • 2995
            the box has to open the router port from newcamd (they all do)
            • Geosat
              • Dec 2011
              • 4
              You have lost me I have opened the port on my router then the box decides to block it hours or sometimes days later
