Newcamd set up correct or not ? VU+UNO
  • ellblud
    • May 2011
    • 11
    Hi educationally speaking here! if someone had a newcamd line and running it on mgcamd 1.35a on vu+uno and was experiencing crashing.What would be the problem is the config file wrong ?
    could somone please check this. Please note when i say this i dont not intend on trying this out its just one of those things i would like to knowledge p.s i had cornflakes this morning !
    # EMM messages
    # 00 don't show any EMMs (default)
    # 01 show only valid EMMs
    # 02 show valid and bad EMMs with complete data display
    M: { 01 }
    # ECM messages
    # 00 don't show anything about ecm
    # 01 normal mode, show pids processed, decoded ecm and cw
    # 02 verbose mode, show valid and bad ECMs with data
    C: { 01 }
    # AU
    # 00 disable, no emm pids processed
    # 01 enable, emm pids always processed for soft-au and shared cards
    # 02 auto, emm started only if channel cant be decoded
    # 03 process emm pids for network cards update only
    A: { 02 }
    # key update (sum 01 or 02 with 04)
    # 01 update only new keys, default setting
    # 02 update all keys (used for valid PMK checking)
    # 04 enable TPS au
    # + tps SID, which pmt pid contains au pid
    U: { 01 } 0x12c0
    # config files folder (softcam, autoroll, ignore/priority)
    # 00 files in /var/keys
    # 01 files in /tmp
    T: { 00 }
    # network mode, use summ for several clients
    # 00 no network (default)
    # 01 newcamd netclient
    # 02 radegast netclient
    # 04 camd3 netclient
    # 08 gbox netclient
    # 32 cccamd netclient, card list saved as /tmp/cccamd.info
    # (ECM only, supported server version up to 2.1.1, later not work)
    G: { 01 }
    # network retry, use summ for several options
    # 00 disable
    # 01 retry every new ecm
    # 02 try to connect to offline shares every Q: seconds
    # 04 try to detect and fast reconnect to lost (and not used atm) server
    # + XX messages number and YY seconds to reconnect
    # mg will reconnect to server, if no answer to last XX ecm/keepalive or
    # if no answer for last ecm or keepalive sent for YY seconds
    # set to 0 to disable
    N: { 07 } 5 30
    # network ecm timeout in seconds
    K: { 05 }
    # newcamd dead routes connect retry, sec
    Q: { 600 }
    # network shares priority
    # 00 gbox, newcamd, cccamd, radegast, camd3 (default)
    # 01 camd3, radegast, cccamd, gbox, newcamd
    # 02 cccamd, newcamd, camd3, gbox, radegast
    P: { 00 }
    # on screen display type
    # 00 No OSD (default)
    # 01 neutrino
    # 02 enigma
    # 03 relook
    # + user password for http auth
    O: { 00 } username password
    # on screen display Options, summ of:
    # 01 show emu ecm
    # 02 show network shares messages
    # 04 show decoding failed / fta
    # 08 show emm keys update
    # + web port to use for osd
    S: { 03 } 80
    # Log option, summ of:
    # 00 off
    # 01 network udp log
    # 02 log to console
    # 04 file, appended ! delete it by yourself, before it eat all your hdd
    # + IP udp-port log-file-name
    L: { 03 } 172.16.1.1 28007 /tmp/mgcamd.log
    # keep ecm cache, seconds
    # every cache entry takes 28 bytes, so 24h cache will take *only* 240-400kb of memory,
    # for openbox/elanvision users with remote shares make sense to set it higher than default value,
    # to not hammer cards while timeshifting or playing crypted recordings.
    E: { 15 }
    # cache option, summ of:
    # 00 Off (default)
    # 01 Ecm pids cache, store pids used to decode in /tmp/ca_cache.list at exit, load at startup, same syntax as restore.list
    # 02 Ecm data cache, remember CW for (E time
    # 04 Emm cache for network cards, do not resend the same emm twice, cache not cleared until restart
    H: { 07 }
    # reread files, summ of:
    # 00 No (default)
    # 01 reread config file on channel change (including priority and ignore, but not replace/cache)
    # 02 reread SoftCam.Key on channel change
    # 04 reread SoftCam.Key if file changed
    R: { 00 }
    # debug, summ of
    # 00 off (default)
    # 01 debug ecm
    # 02 debug emm
    # 04 debug network ecm
    # 08 debug network emm
    # 16 debug network login
    # 32 show mem/cpu stats every 1 min
    # 64 add timestamp to log messages
    D: { 00 }
    # box type
    # 00 autodetect, change only if you think wrong type detected.
    # 01 dbox2
    # 02 dreambox
    # 03 triple-dragon
    # 04 relook
    # 05 openbox
    # 06 dreambox/mips
    # 08 stapi/kathrein
    # 09 stapi/ipbox
    # 11 stapi/openbox
    B: { 00 }
    # map all 180x nagra caids to 1801
    # default is 01
    F: { 01 }
  • mrman2912
    • Dec 2011
    hi everyone
    hi i need help
    • ellblud
      • May 2011
      • 11
      are you spamming my thread or do you have the same problem ? this is for a educational purpose.
      • andy211081
        • 575
        When you say crashing...what do you mean?
        Ladies and Gentlemen, this is your captain speaking. I have the only gun on board. Welcome to Con Air.
        • ellblud
          • May 2011
          • 11
          like small crashing lag on premium channels ?
          • nathan2007
            • Jun 2011
            • 448
            prob a crap server mate
            • ellblud
              • May 2011
              • 11
              Server is freeze free as i know people who are on it and its highly recomended.Is everything in my config file ok ?
              • nathan2007
                • Jun 2011
                • 448
                from experience just becuase someone says server is fine mate it shouldnt be taken at face value server "owners" often give out lines to different servers to minimize disruption when moves and errors occur
                i have had a look at your config looks ok to me mate ..........
                compare the line to your mates and just double check ....
                and of course this is hyperthetical tho so double check with you imaginary friends lmao
                • ellblud
                  • May 2011
                  • 11
                  thanks for the help and ill make sure they get the message
