help
  • mick1965
    • Feb 2010
    • 9
    help
    hello there.
    i need help ,
    how do i input clines on dreambox 800 hd.
    also how to update channel list.
    iam new to all this so dont know wat to do.
    many thanks....
    You need to edit your configuration file and place the line in there. In the case of cccam then it will be in the file /etc/CCam.cfg
    System searching will update your channel list.
    • ramjet
      • 2995
      best checking the dreambox section for questions and answers for this box
      but do as stated above
      as for updating channel lists , for HD use dreamboxedit or dreamset to ftp into the box and load the latest E2 file of your choice
      • mick1965
        • Feb 2010
        • 9
        can you manually input the cline
        • Manic01
          • 5117
          usin DCC , ftp
          var/etc scroll to cccam confg, right click and select edit
          right click and delete everything
          then copy C: line and click on the "edit" at the top of page and select paste
          click floppy icon and save and exit
          reboot box
          goto cam settings using r/c and make sure cccam is set as default and click OK to run/activate
          Thanks @unison
          • Manic01
            • 5117
            you can use remote to enter line, press blue button and select TuxBox Commander navigate to var/etc and edit the CCcam.cfg file if theres no CCcam.cfg file you need to create 1 (mkdir) and name it as said, easiest way to do it is with dcc as other member suggests
            thanks @M4rkyw.
            • ramjet
              • 2995
              or use cuteftp or flashfxp or fireftp or filezilla or any similar ftp program , ftp into box , go to var/etc and add the c line to the cccam.cfg , save and exit
