19.2 and 13.0e
  • markedz
    • 185
    19.2 and 13.0e
    ok i have a monoblock lnb 13.0e and 19.2
    its been working fine but now says on 19.2 no or bad signal check your antenna
    13.0e is working fine,any ideas as what im to do,will or do i need to align dish again,as 13 is fine
    cheers
  • nathan2007
    • Jun 2011
    • 448
    new boquet needed perhaps? load new channel settings onto box mate?
    just ideas but might help if its picking up 13e and its a monoblock cant think that the dish has moved
    • markedz
      • 185
      its a linksat box
      how do i do that then please
      • markedz
        • 185
        just looked at signal and quality
        sig is 70 quality is 40 to 0
        • cactikid
          • 12017
          i have seen a few posts of signal drop with the very high winds
          maybe something has got loose or moved slightly,also make sure you are not on a channel that has moved frequency.
          • markedz
            • 185
            picking up orf ok which is austrian
            but other no
            • mdt
              • 3034
              looks like a slight mis-alignment although check your cables/connectors for water ingress. regards mdt
              • Nutsandbolts
                • Oct 2011
                • 1168
                Hi. Try to adjust the dish by moving it slightly down a fraction. If you get the ORF channels then it cannot be much out of alignment. Regards.
                • bj1
                  • 445
                  sounds like your monoblock has moved slightly.
                  try just turning the lnb a fraction to the right and if signal worsens try slightly to the left
                  .......BJ1
                  • markedz
                    • 185
                    will try the above cheers although
                    they are working fine when there is no rain
                    funny i no,will try after footy today
                    • Manic01
                      • 5117
                      It's alignment issue if ok when sky is clear.
