need another port
  • mapex
    • Jul 2010
    • 209
    need another port
    Hi... i have a belkin router with 4 ports would a port hub
    be what im after or a new router ?
    would the hub slow my connections down ?
    Any one use a hub ? its so i can have my 4 boxes connected
    by wire....just need another port...
  • ramjet
    • 2995
    just add a lan switch , I have a 16 way on one of my 4 ports and a 5 way on another one , and your router is good for about 254 ports anyway
    • Curious123
      • 2591
      I have got about five boxes around the house all hard wired with 'homeplugs' so strictly they are only using a single port.
      • alom5
        • 1648
        that is the easiest and tidiest way i would suggest.
        • lincsat
          • 1228
          If you use a network switch you can have a group of devices in a remote location without needing loads of Ethernet cables. eg if you have your Router downstairs and want 3 boxes upstairs, run a single Ethernet cable upstairs and install a switch, then run the 3 cables from the switch to the boxes. It works well and you're not reliant on the mains wiring being on the same ring-main.
