contant picture breakup and lost of signal message
  • tomnorris0110
    • Jan 2012
    Hi everone my name is Harv can you please help!
    HD box downstairs is giving me grief i am getting constant picture breakup and freezing along with alot of saterlite signal lost messages.
    I have a normal box upstairs i.e. not HD in multiroom set up the TV upstairs is working fine with no loss of signal or breakup.
    Please can you let me know your thoughts?
    Harv
  • cactikid
    • 12017
    maybe loose wire on lnb or water got into cable,if all boxes were the same i would have said dish movement in the very high wind.
    welcome to dk m8
    • tomnorris0110
      • Jan 2012
      further info for your consideration
      Also worth adding to my post above that my signal strength is as follows
      input 1 40%
      input 1 signal quality 60%
      input 2 signal strength 20%
      Also meant to add above that if I switch sky HD box off at the mains and reboot the picture breakup and freezing stops both on live programmes and sky plus recorded progrmmes
      Any input from you guys would be very helpful
      Cheers
      Harv
      • ebyard
        • Dec 2011
        • 46
        Thats pretty poor signal from what are powerful sats. I think you need your dish alignment checked with figures like that. I get 90% minimum on my box.
        • tomnorris0110
          • Jan 2012
          I am a complete novice am I able to re-align my disk or should I get an airiel man in to do it professionally?
          Also does poor signal strength result in picture freezing shudder and breakup or is that going to be a result of HD box cable connection fault etc?
          • cactikid
            • 12017
            very high winds have moved loads of dishes out of sync or into neighbors garden.
            • alom5
              • 1648
              it is your signal problem for sure.... hd channels to work without issue will need minimum of 40% snr...and obviously in the wind....even that may not be enough. 60% is good and stable even in the wind.
