I wonder if anybody can help me with this - I have a place in spain and brought a sky box out to there to watch sky of a communal dish - this works fine but I am from Northern Ireland and Ulster TV at home is on channel 3 but in spain its channel 913 - is there a way to set my box manually to think its back in northern ireland ? thanks
Change region for sky
Tags: None
So I have a card and bring it to Spain even with sky's help can I set my box up withthe handles I have at home? If I brought my card that works at home out to spain and put that in what would I expect to happen? ThanksComment
nothing unless you ring sky up and get them to pair that card to the box. also be careful with what you say to sky as your in breach of their TOC's bu taking the card or receiver out of the country and they could cancel your sub as a result if they were to find out. unlikely but a possibility.Comment
card is only paired to box for sky plus or for movies and sport , nothing else
so a working card without sports . movies and plus will work in any box , and the postcode on that card will regionalise said box for you ( as I said earlier )
so a card from scotland will give different bbc and itv than one from birmingham would
and if you do pay for movies and sport you need the box sly paired it with , or use a spiderbox or dreambox instead
the point here is that the terms and conditions do not allow you to use it outside the uk and so if you ring sly and they know you are abroad they are likely to sanction your account
but you do wahtever you feel you need to do , and you may get away with it , but dont expect miraclesComment
Does the sky card work in a clone box?? I have sky hd and a full sky sub for wife and children and use the dreambox for my own viewing as wife can,t get her head round it and sometimes neither can i.card is only paired to box for sky plus or for movies and sport , nothing else
and what do you think oscam is then ?.
the definition of a softcam.
a software emulation of a Hardware based C.A.M = conditional access module, the primary use for decrypting premium paid for encrypted tv channels with the use of a legitimate subscription card.Comment
the standard softcam relates to a bunch of keys in a txt format called a softcam and is loaded into the relevant box using relevant loaders , such that said keys are used with an emulator like oscam , but more usually the ones listed below
ie:- oscam is a form of emulator , much like cccam , newcamd , mgcamd
so its not what you refer to at all , as they are commonly known as emulators , or emu for short
I use softcams on my dreambox 800HD , blade , spiderbox , icecrypt , tm1500 and tm9100 , along with a suitable emulator
so using a standard definition softcam on any box is irrelevant in this case , whereas using newcs or oscam emulators on a tm9100 or dm800 linux box is
that is what my definition of my answer is , and has been for several years already
so your answer says
but should actually say
the definition of an emulator
ie:-
try opening a softcam file using notepad , then compare it to oscam config files in notepad , you will soon see they are nothing like each otherthe definition of an emulator
the emulators use bin files , a softcam does not , and my dm800 is running oscam dvb-api right this minute , and does not have a softcam in the var/etc folder or anywhere else on it eitherLast edited by ramjet; 8 January, 2012, 00:40.Comment
