Can anyone help me set this up channel lists and how to set up ccam for where to put the line etc cant find much info online at all
Coolstream HD1 setup
do you know what image you have,cccam does not work after 2.1.1,you need oscam,mgcamd and put your sea-lion into a cccam.list. you need filezilla or some ftp client to ftp into the box. its a good box,channel lists go into satellites.xml -> /var/tuxbox/config/and you can make your own here satellites.xml generator / transponder .ini generator
