issue after engineer
  • crispalmer91
    • Jan 2012
    Hi there, I had an engineer come out to fix our dish as it had moved slightly in the wind and we weren't getting a signal. He realigned the dish and done some kind of reboot to the hd box downstairs, that was fine it worked away, he told me to do the same to the box upstairs n it will work. I have tried that and its still saying no satellite signal received anyone know how to sort that? I've tried pulling the power but that's not worked. Thankk you
  • Manic01
    • 5117
    Sky box????????????
    • mdt
      • 3034
      surely the engineer could have checked the box upstairs also... it would have took 5 mins, get him back! regards mdt
      • leon632
        • 129
        check the cable from the dish to the box is in properly and fully tightened.
        If you can't get it going then like the post above, get them back out.
        • alom5
          • 1648
          It will be the cable...check it all the way from the feed
            If it's a sky box i wouldn't worry about it mate as long as your subscribing just keep getting them back until its right, Depending on the age of the box thats more than likely the fault.
