Spurs game on Blade channel 1478 3pm kick off
  • zee24
    • 3342
    ANyone with a blade box im picking up the SPurs game on channel 1478 click on all sats then go to that chanel.
    Usually i only get 1 3pm kick off on Setanta but the odd occasion i pick up another game on this channel or channels nr this 1
  • zee24
    • 3342
    the channel started to show Bburn vs Fulham around 4.45
    • blineboy
      • 25
      any more info on this channel, its not premier sports is it ? and i have less channels then you and only can go up to 1239, so would have to tune it manually to find it
      • ramjet
        • 2995
        the details on this are totally dependent on whose channel list you have used , even if you scanned yourself , so the channel number could vary enormously , which is why its the channel NAME that is important , not the number
        • needy
          • 105
          hi guys need a channel file with multi sat and sky uk in proper groups i.e entertainment, movies, sport do you know if there is one available thanks
          • zee24
            • 3342
            theres no channel name nor did it say on screen but the commentators were skys.
            I havn't used any channel list i just go on blade online click 28.e and then granada region closest to me
            • ramjet
              • 2995
              I think you mean its commentators that you hear on sly , not necessarily their own commentators
              as for the channel list , you have selected the channel list from blademedia`s own website , therefore you have used a channel list , the official one from the blade download site , which is not the one I use , which means the channel number will be different on my list
              • needy
                • 105
                how do you watch somethin on say 13e if you download the 28.2e from the blade online
                • zee24
                  • 3342
                  well since they don't have a yorkshire region on there i download the Granada region channels
                  • ramjet
                    • 2995
                    exactly , so you used their granada region 28e cdf file , their granada region channel list
                    my point is that you reported a channel having football on it by channel number in your database , and unless somebody else has the exact identical channel database your post is meaningless as you did not identify the actual channel involved
                    I could do the same all day long but it would only apply to my own bespoke channel list
                    I appreciate you meant well with good intentions , but its only any good to you and a few others using the exact same list as you use
                    you also said you didnt use a channel list , but clearly you did , the blademedia granada tv region channel list
                    • zee24
                      • 3342
                      ah i was thinking you thought i had got a channel list from another site, i didn't get what you meant.
                      So do most people use different channel lists then and not standard blade ones?
                      Like you said i posted with good intentions i don't even support Spurs
                      Am I right in thinking you still have the 'all channels' menu even with a different channel list? I mean if you go to that and check every channel 1 by 1 before 3pm kick off you may find a game, i know its time consuming but if you've got the patience try it. By the way this channel doesn't pick up games every week
                      • vorlon2257
                        • Sep 2011
                        • 356
                        These channels 1471 to 1479 are the SKY Red Button 8 Screen match choice channels.
                        They are available on all box's using the following info....
                        12070.00 H
                        DVB-S QPSK
                        27500
                        2/3
                        • ramjet
                          • 2995
                          yes you are correct , but obviously for 3pm games on a saturday any red button sly channels are useless anyway
                          and yes they have an ALL CHANNELS but you can move channels around which is why the channel number is meaningless
                          most of us check liveonsat for the channels showing matches and then look for those in our lists , adding them to favourites for easy access
                          if you check the actual satellite its on , and transponder , and check on flysat or lyngsat or kingofsat for it you could identify the actual channel name
                          ie:- for 28e today it would have to have been setanta
                          or for 39e probably nova sport or diema
                          • zee24
                            • 3342
                            I have setanta on 28e where i usually watch the 3pm kick off every week but today i checked the list and found this channel aswell n picked up the Spurs game so i had 2 3pm kick offs today. But i understand your point
                            • ramjet
                              • 2995
                              I have setanta on 28e where i usually watch the 3pm kick off every week but today i checked the list and found this channel as well n picked up the Spurs game so i had 2 3pm kick offs today. But i understand your point
                              LJ,s shows these having that game
                              English Premier League - Week 21 ST: 15:00
                              C+ Multideporte 1
                              C+ Sport (france)
                              Nova Sports 4 (hellas)
                              Sky Calcio 3
                              Sport TV3
                              SuperSport Maximo
                              Tring Sport 4
                              Viasat XTRA PL 3
                              ~ AD Sports HD6
                              ~ C+ Deportes HD2
                              ~ C+ Sport HD (france)
                              ~ Sky Calcio HD3
                              ~ Viasat Football HD (swe)
                              it also lists satellites and transponders for those matches too
                              so as you can see it was on several satellites and several channels as well , your second channel must have been one of them , or a feed
