Bought a blade
  • setfiretorain
    • Jul 2010
    • 934
    Bought a blade
    Bought a Blade 7000HD, Looks like a quality box, Do I need to flash images to it and install cccam etc, or is it already in it like spiderbox ?
    Regards and thanks in advance.
    Sat Boxes
    Dreambox 500s.
    Dishes
    Sky minidish self fitted.
  • potrobber
    • Mar 2010
    • 493
    hi m8
    you keeping well
    blades have cccam and newcamed ready when you flash it with the latest patched firmware you will find on dk then download the channel list from the blade online menu
    then hit 9991 on any channel and there you can enter your line
    they are a good box for the money you will enjoy it
    • zee24
      • 3342
      you will find the latest firmware in the link below, you should always install the patched firmware like the 1 below as the official version doesn't have the 9991 menu for your c line.
      • potrobber
        • Mar 2010
        • 493
        m8
        forgot to say there is a good blade section ash opened for everyone on kings site
        you will find all you need to sort your box
        • billy2
          • 1381
          can i please ask what this box is like over the dream 800hd ??? looking into getting a new box
          cheers
          • potrobber
            • Mar 2010
            • 493
            hi billy
            i would not see any of the 2 blade or bm any better then each other
            it just depends what you want a box for
            if you need a box for hobbie ,intrested in the sat side of things and want a box to spend a lot of time learning go for a dm very good at what it can do being open sourced.
            if you need a box for veiwing sat channels in first class hd and sd picture
            simple to set up 20 mins, simple to use, has a 7 day epg menu ,channel update thru the controller in the blade online menu and simple to record onto ext h/drive. then the blade is the one to go for its very good for a closed sourced box
            • billy2
              • 1381
              thanks m8 see this is the thing i dont like
              • potrobber
                • Mar 2010
                • 493
                hi billy thats why i stated the open and closed source
                and as i said its all about what you want the box for
                i have just ordered a new box from china to test try out which is a copy of a vu duo with twin tuners which should be a good open source enigma2 box and at 200 is well priced for its specs
                so if you hold of in buying for a week or two i can let you know how good or bad it is
                there is a guy on here data7 he has a couple and says there fine so im going to try one
                • D1GG3R
                  • 36
                  Im looking at buying one if these 7000's. Does the external usb hdd need to be mains powered? or will a portable usb drive do the job??
                  Cheers
                  Sent from my GT-I9000 using Tapatalk
                  • setfiretorain
                    • Jul 2010
                    • 934
                    Sounds all good, How is it with usals and how is it with the youtube feature ?
                    Regards
                    Sat Boxes
                    Dreambox 500s.
                    Dishes
                    • potrobber
                      • Mar 2010
                      • 493
                      [QUOTE=D1GG3R;1414929]Im looking at buying one if these 7000's. Does the external usb hdd need to be mains powered? or will a portable usb drive do the job??
                      hi
                      a portable usb drive will power itself from the bladebox no problems
                      setfire i dont use usals yet so cant comment on that but i have not seen anyone complain yet so should be ok and the youtube works ok most of the time
                      • D1GG3R
                        • 36
                        Cheers mate... And thanks...
                        • bj1
                          • 445
                          seems like a nice easy box to set up but can i just ask
                          once you have put the latest firmware in will the box
                          continue to work without having to keep updating
                          the firmware.
                          as this would be a perfect box for my mum,
                          thanks......bj1
                          • potrobber
                            • Mar 2010
                            • 493
                            yes they will run on older firmware no problems and wont timeout or anything like that
                            i have put boxs out last year and they still running lasts years firmware
                            • bj1
                              • 445
                              sounds like a ideal hd box for my mum
                              thanks BJ1
