Blade 7000... how to use DIseq switch ?
  • BigfatPaulie
    • Dec 2011
    • 203
    Hi,
    Just installed my Blade 7000... works a treat on S*Y !
    But being the consummate twiddler I am, I want more...
    I bought a Diseqc (sp?) 2 into 1 switch off fleabay, but how do I use it with the blade ?
    It came with NO instructions - Ive looked at the blade menu, but not sure what to do !
    Also, I have downloaded the channel groups from blade... if I add another satellite, how do I get the group without overwriting what I have ?
    This is the 'bay listing...
    DiSEqC Satellite Dish Combiner LNB 2 Way Switch to 1
    Allows you to connect 2 LNBs(satellite dishs) to 1 receiver
    Technical parameters:
    allows you to connect 2 LNBs to 1 receiver
    signal control of DiSEqC
    950-2400 MHz frequency range
    attenuation of 3 dB;
    separation over 25dB input
    set included cover for rain
    you need to go into the setup menu: Dish Setup and choose Diseqc 1.0 this will then ask you to define which satellite is on which input eg: input 1 19.2e and input 2 28.2e, if you get stuck its on page 14 of the manual
    • rajmallah
      • Jan 2012
      Thanks a milliion works for me now
