Which box? Help..
  • nathan2007
    • Jun 2011
    • 448
    #16
    vu+ duo fit a 3tb hard drive in it will record everything 5.8ghz wireless sender
    vu uno for the single hd tuner
    and a sizeable wedge out of the bank account is spent but a hell of a good setup
    • ramjet
      • 2995
      #17
      I dont think any box can do what you ask , everything is a workaround , and the more recordings you want the more tuners are involved
      generally speaking , for one room only you need a dish with dual or quad lnb , and 2 coax feeds to the twin tuner box ( this is typically sly HD plus )
      then you need a method of sending one channel to other rooms , like sly plus can do using its RF2 output
      a sly plus also is a pvr and can record to an internal HDD
      and lastly you require a method of changing channel , again sly plus does this using the magic eye
      so to do all you ask its probably a vu+ duo as stated in post 2 , the magic eye with infrared blasters added , and the scart to rf adapters to send it using coax cables to each room
      no matter what you do it is complicated and very involved , there is no HARRY POTTER box that can do this , apart from sly plus HD and a sub to sly
      if you remove the record one channel and watch another option , its a single tuner version of the above
      frankly you would have been better to use a spiderbox HD 9000 and not the openbox
      • duglish
        • Feb 2011
        • 87
        #18
        Right.
        Do these 5.8GHz Nikkai send receivers from Maplin work? Will they do the job? It says that you can change channel aswell with remote. Im gonna buy TM5402 or a Galaxy 3000 HD to do it
        Yes he's taken this long to get back to me!!
        All help appreciated and ASAP
        • Manic01
          • 5117
          #19
          I use aei digisender, works with anything.
