wired correctly?
  • dicey2
    • Dec 2011
    • 8
    wired correctly?
    i have a quad port lnb pointing to astra 28.2 east. 2 cables go into a diseq switch and the other 2 go into another diseq switch. a cable then runs from each diseq switch into 2 seperate comp receivers which are pvr ready.
    now the problem i have is that neither receiver allows me to watch one channel wilst recording another channel even though the receivers are capable - opticum 9600 prima ts and a opticum x703
    is my cabling correct or have i done soemthing wrong? do the cables from the lnb have to be in specific ports and the same with the diseq switchs?
    im confused
    You cant send 2 feeds into a diseqc switch and then down 1 cable and expect to be able to wacth one channel and record another, A diseqc swict isjust that it lets you switch between ports whether there are 2/4/8/16 ports.
    you would be better just attaching 1 feed each directly from the dish into both of your receivers. So then you can watch one channel say on the 9600 and record a different channel on the 403.
    Get rid of the diseqc switches unless your going to add other lnbs for different satellites.
    • nibblitz
      • 1300
      As above, you dont need the switches, run feeds straight from the LNB to the boxes.
      • dicey2
        • Dec 2011
        • 8
        i have a second quad lnb ready to install which will point to hotbird. thats why i was using the diseq switchs.
        so to achieve what i want in my original post what do i ned to do?
        • dicey2
          • Dec 2011
          • 8
          let me ask it another way.
          if i want astra and hotbird going to the one receivier and be able to record one satellite channel whilst looking at another satellite channel how do i achieve this and how many/where do i run the cables?
          i assume i will need to change my receiver?
            You will need a twin tuner receiver 1 feed from 28.2 to Tuner A and 1 feed from Hotbird to Tuner B this will then let you record from either 28.2 or 13*? while watching a different channel on the other sat.
            • RimaNTSS
              • Apr 2011
              • 9
              2 Author! Get additional 2 DiseqCs and connect all your wires like in attached diagram. If you are going to extend numbers of LNBs in the future than better use 1/4 DiseqCs instead of 1/2 as shown on diagram.
              • dicey2
                • Dec 2011
                • 8
                thanking you
                • dicey2
                  • Dec 2011
                  • 8
                  thats perfect!
