I am getting myself a new Inverto Black LNB - Are they easy to change...??
Loss of signal on premier league Hd 4.8e
thank you for replyJust going of the SNR margin for the box itself i get 67% on 12.092V on ultimo and only 57% on DM800se and on 12476V i get 73% on the ultimo and around 64% on the Dm800se 12437V is unavailable for me.
The Dm800se is a clone so have no idea if an official one would give better readings
Hope this helps
your result Is fine
Vu ultimo 2 x DVB s2 I got have a problems with locking some of V pol transponders on upper Ku band
did you open your box (to mount hdd) - I wonder what Is hardware revision on your DVB s2 tunerComment
If you spend time and using a good meter you can get 100%. ( not always possible to spend ages on this )
I spent time and changed the angle of the lnb ( a few times ) and i got 100% V and 100% H all be on the quality but have never had any issues.
This was on a 1.1 metre dish.Comment
I was just about to comment that if your getting 100% AGC and 100% SNR not from a meter but from an actual receiver on the 4.8? Nordic beam then your either Located in sweden and or norway, Cause i cant get anywhere near those figures on a Triax 1.1 or a Gibby 1m on a bigger dish yes but not the 2 i mentioned, If your nearer the east coast then your figures should be in the 90's on that size of dish
Agreed, and the Gibby is much better than triax as wellI was just about to comment that if your getting 100% AGC and 100% SNR not from a meter but from an actual receiver on the 4.8? Nordic beam then your either Located in sweden and or norway, Cause i cant get anywhere near those figures on a Triax 1.1 or a Gibby 1m on a bigger dish yes but not the 2 i mentioned, If your nearer the east coast then your figures should be in the 90's on that size of dishComment
Here we go again the same pub has called me out today and says since in changed the lnb the other week its been perfect in all weathers but around 2pm today the prem league hd is showing no signal its has been raining but only fine drizzel so thats not gonna efect it also its still not come back on after the rain has stopped all the other channels are working perfect
think i will go and pick the box up and bring it back to mine and try it on my dish to see if its a tuner issueComment
