Oscam for windows and smargo probs
  • steve67474
    • Mar 2010
    • 98
    Hi Guys. I have just loaded this file on my PC...OSCAM-1.10svn6089-i386-pc-cygwin-libusb-pcsc-webif-OSCAM_LoaderV0.1.4 and tried to configure a smargo on it. I followed these directions to the letter...
    1. Unpack the tools zip file to Desktop
    2. Plug the smargo into a USB port on your PC.
    3. Windows will detect the new device.
    4. Do a manual drivers install , pointing to the Drivers_Windows folder.
    5. It will prompt for drivers for the USB device , then again for the serial device.
    OK, the drivers are installed
    UPPGRADE FIRMWARE
    Make sure the smargo is plugged into the PC with NO viewing card in it.
    Firstly, we need to check the smargo firmware version, so run the SmartreaderUpdate.exe
    If the firmware is v1.4 it will say so in the status bar at the bottom of the window and you can close this util,
    if not, click the update button and it will apply the update.
    CHANGE PORT COM NUMBERS
    on your pc
    in device drivers > PORT COM & LPT >
    you have a new interface : USB Serial Port com (com xx) xx it's a port number
    right click > propriety > port setting > advanced >
    change : COM Port number
    Then I did this to Identify the Bus No.
    command for looking N? of BUSEV for Oscam loader cygwin
    run cmd in windows
    type cd c:\Oscam\OSCam <= path folder oscam on your HDD for me it's C:\Oscam
    type list_smargo.exe
    other windows open with
    FTDI
    bus:dev 002:003
    Device Serial:Reader xxx for me xxx = 227 =>
    oscam device = Serial:Reader 227
    start Oscam_Loader
    chose : smartreader
    detect : CD
    device : Serial:Reader xxx
    caid : your caid card
    label : your name card nc bis sly ect
    The result was this???
    Microsoft Windows [Version 6.1.7601]
    Copyright (c) 2009 Microsoft Corporation. All rights reserved.
    C:\Users\Steve>cd desktop
    C:\Users\Steve\Desktop>cd oscam
    C:\Users\Steve\Desktop\OSCAM>cd oscam-1.10
    C:\Users\Steve\Desktop\OSCAM\OSCAM-1.10>cd oscam
    C:\Users\Steve\Desktop\OSCAM\OSCAM-1.10\Oscam>list_smargo
    Looking for smartreader with an out endpoint = 0x82 :
    coulnd't open device 006:001
    Any ideas whats going wrong guys. I did the driver update and this is my driver in Device manager...
    Learn how to hold a bear with a mic in your hand Kylie LOL
  • steve67474
    • Mar 2010
    • 98
    cracked it
    FYI Guys I found this program called ZADIG.EXE and this installed the correct driver for the smargo and it listed ok
    • rodnay
      • 19
      hey chap, just wondered where you got that info from?
      and thanks for sorting the prob out and then posting your findings, s'what forums are all about eh!
