19.2e/astra 2
  • jon48
    • Apr 2010
    • 147
    19.2e/astra 2
    hi all,/ the problem im getting is when i scan on 19.2 e im not picking the channels up on that tp im picking 28.2e channels up instead ive even done a manual scan on it and still not the correct sat any 1 got an idea on this 1......
    blade 7000 latest fw
  • cactikid
    • 12017
    dish has moved.
    forgot to add most fixed dish are set to astra2 28.2
    • dick b
      • Jun 2009
      • 2462
      your dish is not aligned. set 11.597V 22000 BBc world on 19E as this TP is not on 28.2.then use this to get max signal when realigning your dish.
      • mdt
        • 3034
        are you using usals?... dish would have to move a large amount on the mounting pole to be 9 degrees out. drive the dish to zero via the menu re-enter your lat/long and re-boot ect. make sure that the problem isnt stb related before getting the ladders out or getting someone in, regards mdt
        • jon48
          • Apr 2010
          • 147
          19.2 e
          yes lads i think its stb related ive done a factory setting and readded the fw and loaded the cndf and its now scanning the only problem i have is i cant watch sky sport germany the cs is there but no pic for footy ?
          • cactikid
            • 12017
            i would check the info on kingofsats for tp info on that channel
            and check the info on your box to see if its wrong and channel has moved,a manual scan should get it back then.
            assuming dish is pointing to astra1?
            • jon48
              • Apr 2010
              • 147
              yes thanks for the info ive just been on kingofsat and manual added the tp and it still does not show the footy just a blank screen m8 it must be my cs server im wondering if he is subscribed to all the footys like he says ps i can get tring on no probs but any othe footy i cannot get ?
              • ramjet
                • 2995
                are you getting the fta channels on 19e ok ?
                examples:-
                sport 1 12480V 27500
                Arte HD 11361 H 22000
                ZDF HD 11361H 22000
                De Luxe Music 12246V 27500
                • jon48
                  • Apr 2010
                  • 147
                  19.2e
                  examples:-
                  ZDF HD 11361H 22000
                  yes m8 im getting all the free channels except sport 1
                  • ramjet
                    • 2995
                    well , sly sport germany is on 12032H 27500, which I get and I get that sport 1 HD fta channel too as it has basketball on it
                    sly sport HD1 is on 11914H 27500
                    obviously they wont open if your provider isnt supplying the k&ys
                    • setfiretorain
                      • Jul 2010
                      • 934
                      The person who provides your c/s may not subscribe to this channel, We can't really say much on the subject in open forums.
                      Through me a PM.
                      Regards
                      Sat Boxes
                      Dreambox 500s.
                      Dishes
                      Sky minidish self fitted.
                      • Manic01
                        • 5117
                        Can you see an epg for that channel, if there is no epg then you are not on the correct channel.
                        • jon48
                          • Apr 2010
                          • 147
                          19.2e
                          yes there is an epg on the site and it updates
                          • Manic01
                            • 5117
                            Is it the correct epg for that channel.
                            Maybe your cs is for sd not hd.
                            Check both.
                            • jon48
                              • Apr 2010
                              • 147
                              19.2e
                              yeah its hd m8
