advice on dish setup
  • potrobber
    • Mar 2010
    • 493
    #16
    Originally posted by dick b
    you could have say 3 single lnbs going to the 4 way diseqc switch and one output of a twin lnb also going to the switch and the 2nd output from the twin lnb going straight to a stb tuner.(if thats what you mean)
    thanks dickb digicon and mdt
    this is what i will go with
    1.2 gibertini dish
    3 single good quality lnb,s
    my quad lnb
    1, 4 way diseqc switch
    a 4 lnb bracket
    this to me seems the way i would like it to work correct me if im wrong we record a lot on 28.2
    so 1 feed from quad lnb into tuner 2 on duo, two feeds from same lnb to bedrooms and forth to switch
    then all 4 feeds 3 single lnb,s and last one from quad thru switch to tuner one and i can then watch any 1 of these 4 sats while still recording 28.2 on tuner 2 is this correct? will this work on no1 tuner in duo?
    ive no intrest in recording on other sats so dont see the need for twin lnb,s
    and for going with motor set up the above cant be done as dish will only point at one sat , so that rules out motorised set up
    thanks for all the help with this
    • digicon
      • 8261
      #17
      Your correct on your setup, but it can be done with a motorised as well the only thing you gain from having a Multi LNB setup is the speed of Zapping to a different channel on a different Sat.
      If your happy with the Fixed 4 sats you want to receive then your setup cannot be beat for zapping speed, The only downside is your fixed to those 4 sats. With a motor you have the freedom of X amount more thousand channels than what you would have with your Multi LNB.
      Good luck with the Install
      • potrobber
        • Mar 2010
        • 493
        #18
        hi digicon
        how do i keep recording 28.2 and move dish to say 13e to watch that sat with motor setup ?
          You can't, to record from 2 satellites at the same time would require either 2 dishes or a multi lnb dish
          • digicon
            • 8261
            #20
            Originally posted by potrobber
            hi digicon
            Sorry Dude my bad, with all the installs i do over here most already have a fixed sky mini dish so basically we take a feed from the Quad on the fixed mini straight to Tuner B and then Motorised on Tuner A.
            I now realise you will only have the fixed 1.25m at your location so a multi LNB is the wisest choice unless you did put up a fixed dish for 28.2?.
            Again apologies scrap what i said in my previous post its late LOL just stick with the Fixed Multi feed.
            • potrobber
              • Mar 2010
              • 493
              #21
              thanks digicon
              i had thought about leaving dish up but where its at, front corner of single story 2 dish,s would just look bad i think
              i will be happy with one dish fixed and 3 lnb,s pointing at different sats and 28.2 on 4th lnb
              can i now ask whats the best 3 sats to point these at for movies and documentries in english languge
              ive no intrest in football channels and im sure youve guessed from my questions not much of a clue on all this sorta sat stuff
              thanks for your good advice everyone
              • setfiretorain
                • Jul 2010
                • 934
                #22
                Sats I would go for personally for that would be :
                19E
                13E
                0.8W
                If you get a dish big enough to pick them 3 sats up along with your UK on fourth LNB you are laughing mate would be a smashing and solid setup!
                No waiting for motors to drive either !
                Regards
                '"If you can't make decisions in life, you're a bloody menace. You'd be better becoming an MP!"
                Quote from Mr Shankly, YNWA, JFT96
                Sat Boxes
                Spiderbox 7000 HD with " gift "
                Dreambox 500s.
                Dishes
                1.1 Motorised triax satellite dish single LNB.
                Sky minidish self fitted.
                • shankill2012
                  • Feb 2010
                  • 285
                  #23
                  Hi mate , I'm in central Belfast and Im in the process of setting up multi lnb , using triax 78, multi lnb bracket ,inverto lnb's , and using my old quad sly to feed directly to kids rooms and 1 feed going to disqec switch with other lnb's, I have got sats- 28.2e, 23.5e,19e,13e, and did have 0.8 west but I've only got a 4x1 Discq switch ( waiting on a 8x1 coming) but u shouldn't have a problem getting a lot of sats especially with your bigger dish - just a little bit of tinkering getting the angle of your bracket right, 28.2 will be highest to your left looking at your dish from the front and 0.8 will be lowest on the right hand side .ps I started off wanting 4 sats and now I'm wanting 8 ! .
                  • dick b
                    • Jun 2009
                    • 2462
                    #24
                    Just to add mate if you get the gibertini dish they also do a multi bracket to suit check out HISAT : Motorised Satellite TV, Big satellite Dishes, Sharing satellite TV receivers, Decoders, Cards, In Stock, Gwynedd, North Wales, UK they are not the cheapest place but 100% reliable(and the dish will come from them wherever you buy) I found the bracket easy to adjust as some LNBs will need to be higher/lower on the bracket than others as outlined by"shankill2012",I cut spare rail off one end and bolted it to the main rail by the existing slots and used long bolts to get the rise and fall needed.I found this method easier than trying to tilt the LNB bracket or dish.
                    • shankill2012
                      • Feb 2010
                      • 285
                      #25
                      Also this is an easy and cheap way to add extra lnb's to your bracket without having to buy extra holders, simple hose pipe connectors.
                      • mdt
                        • 3034
                        #26
                        thanks digicon
                        wait untill you see the size of the gibby 1.25 m8 regards mdt
                        • bj1
                          • 445
                          #27
                          [QUOTE=setfiretorain;1459833]Sats I would go for personally for that would be :
                          19E
                          13E
                          0.8W
                          Regards[/QUOTE
                          if you are only after these sats a 1.25 gibby would be a waste of money, a 80cm dish would give ample signal and
                          looks a lot better than a 1.25 gibby.
                          ...BJ1
                          • potrobber
                            • Mar 2010
                            • 493
                            #28
                            hi all and thanks for all this input
                            i want to get this ordered and have just seen shankill,s posts he is local to me and if he is getting them sats on a triax 78 surly i dont need the 1.25m dish
                            postage from hisat is crazy to here i could fly over and back for what they are looking
                            so starting to think 1.1 triax dish 3 black ultra lnb,s bracket for lnb,s and diseqc switch this is what im going for and ordering in the morning
                            again thanks everyone for all your input
                            • gracieboo
                              • Dec 2010
                              • 368
                              #29
                              Hi potrobber. Ive talked with before as you know you are not overly that far from me. I have a 1.1m dish and i can get every sat needed here. What sats are you after and i can tell you if im able to get mate.
                              • potrobber
                                • Mar 2010
                                • 493
                                #30
                                hi gracieboo you well m8
                                dish is ordered im looking what ever sats broadcast the most in english and im not intrested in football
                                setfire has said to go with these
                                19E
                                13E
                                0.8W which i think i will try and see how it goes
                                thanks for letting me know 1.1m dish is enough
