Motorised vs Multi LNB
  • thevilla1
    • 78
    Hi again,
    well i might have a change of plan from my motorised project.
    (im also very new to all this!) so forgive me for stupid questions!
    ive learned that the dish doesnt have to point at the sat...only the lnb has to do that (told you i was new) .. so as i only want skyuk + viasat.. is it possible to just have 2 lnbs and point 1 at each sat?
    or is 28.2 and 4.8 to far apart for 1 dish?
    if the multi lnb works...id get a 4 way multiblock..and just add another lnb as and when..
  • Manic01
    • 5117
    Massive gap.
    Motor is best, and will give you lots more like fta premier darts on 19.2e along with boxing/fa cup etc.
    Loads to be had free in epl footy on 7e.
    • thevilla1
      • 78
      cheers again... sorry to be a pain in the butt!
      i think i`ll go the motor route then
      ta
      • sambhi92
        • 293
        Whats open on 7e for free?
        • Manic01
          • 5117
          GRTS fta epl on sat 3pm ko
          10721 V 27500
          • sambhi92
            • 293
            Cheers Manic, will keep an eye out for that. English com?
            • Manic01
              • 5117
              Yes, from AD sports.
              Pic quality sometimes good sometimes poor.
              • shankill2012
                • Feb 2010
                • 285
                I can get a distance from 28.2e to 0.8w on a 80cm dish with multi lnb bracket so you could maybe get 4.8e using multi lnb bracket, but I also have a 1 metre dish with motor and can get a lot more satellites than you will ever get on any lnb bracket, dish & motor is easily the best set up.
                • Blueorson
                  • Feb 2010
                  • 12
                  28.2 too 0.8 on multi lnb
                  28.2 too 0.8 on multi lnb ?
                  what set up is that as never seen a off the shelf bracket more than 20 degrees apart
                  Agree with motorised is best, but for the none enthusiast or the sport/film only users, then a fixed dish/dishes and multi 1.1 switching is easier
                  have both the above you could call it his and hers
                    To get the Nordic beam and Viasat on 4.8? east and to allow for good rain fade margin you would need a 1m or better still a 1.1m with 4.8? as your main sat and 28.2? east as your offset LNB
                    • excollier
                      • 187
                      10721 V 27500
                      What's on tomorrow, not listed on lj's
                      Get to the Ulster Grand Prix
                      Dundrod Co. Antrim
                      Every August
                      Learn what fast Really is!
                      NOT for the faint hearted
                      or watch it on BBC NI HD the following week
                      (What is football all about?)
                      • shankill2012
                        • Feb 2010
                        • 285
                        @ blueorson, "what set up is that as never seen a off the shelf bracket more than 20 degrees apart
                        have both the above you could call it his and hers " Got it off fleabay mate ? 15 quid , this is it on dish and on its own. i know its horrible looking at the moment but im only getting it up and running ,waiting for an 8x1 disecq switch to add some more sats and then clean it up when im done.
                        • flomania
                          • Feb 2012
                          hi
                          motorized for sure
                          • thevilla1
                            • 78
                            i was looking at those...but they only have a 20 degree spread..unless im mistaken... im gonna go motor though i think...thanks for everyones imput though
                            • saj1985
                              • 785
                              i think its FTA chelsea v bolton 3pm kick off on grts1 7e
                              Dreambox 800hd se/Dreambox 500s, 90cm Solid Dish, Tm2600 Motor, TM-1 Gold LNB!
