Monoblock
  • thered
    • 4915
    Monoblock
    Monoblock problem
    does the monoblock sit in reverse ??
    if i clamp hotbird lnb surely astra is to the left (looking from dish down lnb)
    read somewhere its on the right but right is more west
    dont understand 19 east is more east than 13 east
  • chopps
    • Aug 2011
    • 39
    If you think of your dish is a big curved mirror reflecting the signal on to the LNB, you'll see why it's the wrong way round.
    • shankill2012
      • Feb 2010
      • 285
      Yes sats will be opposite of what they normally are- 19e on the left and 13e on the right looking at the front of the dish
      • ramjet
        • 2995
        kick a ball at an angle against a wall (wall-ee ) and it bounces AWAY from you, so an easterly sat signal bounces on the dish and requires the lnb to be further west in order to receive it
        so looking from the front of a dish where the lnb sits, into the curved rear , the lnb is pointed at hotbird at 13e and as astra is at 19e then the bouncing signal rule applies which means the astra lnb is positioned to the left and slightly higher up than the hotbird lnb in its final resting place in order to pick up signals from astra
        so its about where the bounced signals end up in 3D space relative to the alignment lnb, not where they actually originate from
        • bj1
          • 445
          visit dishpointer.com to get elevation settings for hotbird line up dish to hotbird then looking from behind the dish raise the right side of monoblock to 2 oclock..ish....... fine tune by turning
          lnb to position of highest signal quality...BJ1
          • dick b
            • Jun 2009
            • 2462
            with 13E as prime it should look like this.
            • thered
              • 4915
              thanks for all the replies be a weekend job now but it starts with tuning hotbird first i gather and i heard a rumour that if i cover 19 up with tin foil it will be easier to set???
              do i have to set diseq for a monoblock or will the receiver auto both satellites ??
              ty
              btw dont know what the box is
              • bj1
                • 445
                i dont know about the tin foil ....if you follow the steps shown
                you should have no probs. and yes you do have to set your switch type to diseqc or on some boxes toneburst....BJ1
                • ramjet
                  • 2995
                  ty
                  dont need tinfoil , even a towel or similar will do it , and yes its better to deal with one at a time , starting with the prime focus lnb, then moving onto the second one
                  yes you have to set the box up , no its never auto
                  • bj1
                    • 445
                    ramjet what do you need to cover one up for?
                    • mdt
                      • 3034
                      ive never needed to cover the secondary focus lnb feedhorn on the 20 or so mono-block systems ive installed.. regards mdt
                      • bj1
                        • 445
                        what good would it do?
                        • ramjet
                          • 2995
                          seems simple enough to me , if you dont cover it up and you havent got the monoblock setup correctly on the diseqc you will focus the dish using the wrong lnb, as either lnb can be used for setting up, and if the wrong one was used the other would not pick up your second satellite
                          therefore a simple cover up of the astra lnb allows you to concentrate on getting the hotbird one lined up , and then you uncover the astra lnb and check it, fine tuning as necessary. it takes 2 seconds to cover it with a small towel, and 2 seconds to uncover it, so whats the problem here ?
                          buy hey , what do I know ? dont cover up the astra lnb at all and do it all your own ways, makes no difference to me what you do, some people are just too pedantic and seek to troll answers just to try and take the moral high ground , a forum should be about exchanging ideas, not one-upmanship
                          • bj1
                            • 445
                            sorry if i upset you ramjet
                            i just thought there was something
                            i was missing out on.....
                            any helpfull tips are taken on board
                            .....BJ1
                            • shankill2012
                              • Feb 2010
                              • 285
                              Sounds like a good tip to me, after setting my first monoblock up a matter of weeks ago and not covering 1 up I soon realised I had the satellite on the wrong lnb and had to go out and move the block further down the rail to get 13e and 19e, you could also put your hand over each lnb in turn and see if the signal dies .
