DiSEqC switch problem
  • gracieboo
    • Dec 2010
    • 368
    Hi there guys ive just installed a multi lnb set and im using it on an old technomate 5300. Ive checked all the sats indvidually and they are all fine, i have a 2 way diseqc switch and i can switch between any of the the two sats at a time that i have connected to the switch. So today i bought a 4 way switch but when i connect it up i get nothing. The 4 way switch says its diseqc 2.0 so my question here is have i bought the wrong 4 way switch??? as in my settings for the technomate have only got 1.0 , 1.1 , 1.2 and usals. Any help greatly appreciated.
  • ramjet
    • 2995
    Originally posted by gracieboo
    Hi there guys ive just installed a multi lnb set and im using it on an old technomate 5300. Ive checked all the sats indvidually and they are all fine, i have a 2 way diseqc switch and i can switch between any of the the two sats at a time that i have connected to the switch. So today i bought a 4 way switch but when i connect it up i get nothing. The 4 way switch says its diseqc 2.0 so my question here is have i bought the wrong 4 way switch??? as in my settings for the technomate have only got 1.0 , 1.1 , 1.2 and motor. Any help greatly appreciated.
    try setting it to diseqc v1.1 and have the first sat on committed 1 and uncommitted 1 , and the second sat on committed 2 and uncommitted 1
    this leaves 3 and 4 ready for further expansion
    • gracieboo
      • Dec 2010
      • 368
      Thanks ramjet but im unsure how to do that. I did change the two way switch on in the 1.0 and it worked fine. so should i go into the 1.1 witch has the 16 switch settings? im then still un sure what you mean about the commited and uncommited. is there an idiot proof way to explain it to me. many thanks for replying. I just pressumed in the end that the switch wasn,t compatable with my setup.
      • ramjet
        • 2995
        I cannot tell you the settings in your technomate
        all I can do is advise on setting it up and trying the committed and uncommitted, and I would have thought the diseqc setting up may have been in your manual
        so for a 4 way switch , you set the settings to 1 , 2 , 3 , 4 for committed and 1 in all four settings for uncommitted
        the simple diseqc of A, B, C, D should have worked, but if not its the commit and uncommit that need altering to suit in diseqc v1.1
        • bj1
          • 445
          i have the same set up on my protek 9710 on 13e 19e 28e and i have the same switch aswell i set mine up on diseqc 1.0 even though the switch is diseqc 2.0. when i first set it up it would not work and i found that if i put a forth cable from one of my quad lnb
          it works fine so now my set up says
          LNB1 13 E
          LNB2 19.2 E
          LNB3 28.2 E
          LNB4 28.2 E
          so all 4 have to be connected for this to work on diseqc 1.0
          so if you have any spare ports on any of your lnbs just simply connect a cable from it to your spare port in your switch and it should work.
          • gracieboo
            • Dec 2010
            • 368
            Cheers bj1 and ramjet. bj1 i did as you said with the 4 way switch and connected the four lnbs ports up but still only two would work this time 28 east and 39 east. So i tried serveral different permentations of the set up but still no joy. So then i ran two lenghts of coxial one from 39 east and one from 19 east and just behind my reciever i connected them to a two way switch that i have and they worked fine . But when i put the switch beside the dish and run two short lenghts into the switch then one longer lenght of coaxal to the reciever i get nothing. Just to make sure, i done it again by running two lenghts from the two lnbs and putting the switch behind the reicever and again everythings fine but as soon as i do the other way with the switch beside the dish i get nothing???? ive tried it half a dozen times and its the same result. im baffled
            • gracieboo
              • Dec 2010
              • 368
              Still no luck. Dick b if you read this your help would be greatly appreciated as i know you know a thing or two about technomates. cheers.
              • bj1
                • 445
                check your cable and connections on the feed for your switch
                if it works behind your box it should work anywhere as long as your cable run is not to long.
                • patkins
                  • 3662
                  diseqc switch.jpgFor what its worth......
                  When you sort out the 4way switch you can, if you like, connect the out cable from the 4 way switch to one of the in connections on the 2 way leaving you scope for adding more sats to the idle connection.
                  • gracieboo
                    • Dec 2010
                    • 368
                    Ive just set the sky dish up at my dads house and connected all the leads individualy and all sats 19/28/39 east are fine. So again this time with a technomate 4 way switch i done patch cables from lnbs to switch that i cable tied to the back of the dish and one cable to the reciever. Im getting 19 east and 28 east fine using the switch but still no joy with the 39 east even thou its lined up on it I then tried 39 east and 19 east and took 28 east out and it worked for 19 and 39 but when i add in 28 east i can,t get it???. I then tied 19 east and 39 east from that dish and took a feed from another neighbours dish for 28 east just to make sure that it wasn,t some sort of signal overload on the zone 2 dish i was using, but again once i added the 28 east cable i can,t get 39 east. I think ramjet said something about covering the other lnbs with a clothe would this help in my situation even thou it aint monoblock??? Sorry for such a long winded question/explaination but this is doing my nut in over something thats probably simple. Thanks for any help guys that yous can give.
                    • ramjet
                      • 2995
                      my answer of covering an lnb up on a monoblock was in relation to lining up a monoblock on a single dish using the correct lnb from the 2 lnb`s contained in a monoblock for the purposes of lining up only
                      it as nothing to do with using single lnb,s and a diseqc switch , or to do with any switching issues either
                      • gracieboo
                        • Dec 2010
                        • 368
                        Just read a abc guide from whatsat saying that for every 5 degree seperation on the lnbs the dish size needs to increase 20% or so. So maybe when im putting the third in its overloaded with signal??? Don,t know how to do a link to it but if you can google whatsat abc guide to seeting up multi feed satellite dish and let me know what yous all make of it. many thanks ramjet.
                        • ramjet
                          • 2995
                          Just read a abc guide from whatsat saying that for every 5 degree seperation on the lnbs the dish size needs to increase 20% or so. So maybe when im putting the third in its overloaded with signal??? Don,t know how to do a link to it but google whatsat abc guide to seeting up multi feed satellite dish and let me know what yous all make of it. many thanks ramjet.
                          I do not believe that has anything to do with it either , seems to be clutching at straws to me, from your description they seem to be advising a bigger dish being required when spacing lnb,s out on a lnb rack, which is correct
                          back to the facts:-
                          a 4 way diseqc switch is normally 4 to 1 , meaning 4 lnb inputs and 1 receiver output, and can only be switched to one at once, so its like a 4 way switch that only allows connection from the receiver to each lnb in turn, this is the A B C D scenario
                          when connected to one lnb the voltage is connected as well and that lnb works , the others are all switched off and receive no voltage or tones and so are "dead"
                          using diseqc v1.0 you would normally set A to astra at 19e , B to hotbird at 13e , C to astra2/eurobird at 28.2e and D to say bulsat on 39e ( in my case I have D on hispasat at 30w )
                          diseqc v1.1 can also be used which is where the commit and uncommit come into play , where uncommit is always 1 for a 4 way switch
                          seems to me that as each cable works direct but has a problem with this switch , its either a switch or a settings problem , bearing in mind that the F connectors have to be correctly attached with the f connector touching the outer screen for earth
                          it would help if you could try a different make of 4 way switch too, as well as trying commit and uncommit in diseqc v1.1
                          • mdt
                            • 3034
                            probably a faulty switch!, a 4 way switch should work using diseqc 1.0. regards mdt
                            • patkins
                              • 3662
                              When working with switches before I got trouble from screwing in cables which resulted in the blob of solder (keeping the connection rigid) cracking.
                              So I made up four short runs of cable and fitted them to the inlet end permanently and made all my connections then to the short run cables with barrel connectors.
