help if you can please on latatudie and elevation. for the area code of cv31. i have a dark motor and a 1 meter dish. with a spiderbox 900hd.. the thing that i don't understand is i have 2 latatudie and elevation on my motor one that fits to my motor and one that goes onto my motor and dish. i am very confused here. how good should a 1 meter dish be with the spiderbox thanks you all lee.... ps please forgive my spelling mistakes
help if you can please on latatudie and elvation
According to your Postcode the latitude is 52.3 for the motor so on the motor latitude reading side put the small mark on the 52 setting.
Your dish elevation is setting a starting point of 23 but take this with a pinch of salt it could be anywhere between 23 and 30
From your postcode above i get these from dishpointer
Latitude: 52.2721?
Longitude: -1.4988?
These need to go into your Spiderbox Motor settings
your dish elevation comes out at 23? but as i say take this with a pinch of salt you dish elevation could vary between 23-30.
Regards
thanks mate. but my longitude has only got 4 numbers i can put in and the latitude has only got 3 in it with w and north settings cheers lee sorry mate will i need to update the box first to get the channels or not it is a brand new spiderbox 900 hd software f4.37 ldr ver 00.31 hardward version ver 01.20.rm ptc (ok) last update oct 10 2011 cheers mate leeLast edited by youngie1; 7 March, 2012, 11:30.Comment
the box will be a 9000 HD , not a 900 (unless its a 9900 )thanks mate. but my longitude has only got 4 numbers i can put in and the latitude has only got 3 in it with w and north settings cheers lee sorry mate will i need to update the box first to get the channels or not it is a brand new spiderbox 900 hd software f4.37 ldr ver 00.31 hardward version ver 01.20.rm ptc (ok) last update oct 10 2011 cheers mate lee
the box will need patching with the 15 nov 2011 patch if its a 9000 , or use the latest 9900 patch if its a 9900
you can use any spiderbox HD channel list , or make your own
as for your usals settings on your box , they are as follows
001.5W
52.3NComment
Hi. In my TM5400 SUPER i have the lat and long set as follows: 00.0W and 00.0N. (it should be 00.1W and 51.5N for London). The motor still goes from 30 West to 45 East with no problems. I can never understand what this latitude and longitude figures are meant to do. If using USALS and you sent the dish to 30 West it will go to 30 West , if you send it to 45 East it will go there etc. I believe that to get the signals from the satellites depends on how you set up the dish on the motor and the way your LNB is focused . Remember if using DISEQC(1.2) you dont need any latitude and longitude figures and the satellites are still found. Maybe somebody can explain to me why USALS needs the latitude and longitude figures. Regards.Comment
Basically because USALS is software based and so when entering your Lon and Lat details into your receiver this gives it exact location information on where abouts you are in the world.
The receiver then talks to the Motor again which is software controlled and tells it you are HERE so to speak and the tells it to go to 30 west, The motor has this information and so turns to 30 west and so on.
I have tried to word that as simple as i could to avoid bogging you down with technical mumbo jumbo
