Sly F1 What do I need
I already use this dish for normal freesat as my digital service round here is complete shit so would have to be something i could use for bothComment
Sky Digital is at 28'e, RTL is on 19'e (which was the position we all used for analogue sky).
RTL is showing all the F1 events FTA so you need to be able to pick that position up, I guess 2 ways.
1. Motorize your dish (if your reciever supports it)
2. Install a 2nd dish pointing at 19'e (mini dish should do) and use a disque switch (or even a manual one if your reciever don't support it).
If you are looking at a cheaper alternative to get f1 for less than 35 a month, then for 35 you could buy and fit a 2nd dish and even swap the coax manually before a race and watch all races for the season.
SSComment
Not the ideal solution but you could always Tape or cable tie another LNB to your Quad thats on there now might need a bit of padding in between to get the spacing right but it will work.
or you can either buy a multi-lnb arm or try and cobble one together yourself
Not sure if a mini dish aimed at 28' could handle so much of an offset of 10' ?
Maybe aim the dish midway (say 24') then offset both lnb's around 5'.
But if you don't use 28'e freesat, then just realign to 19'e.
SSComment
No it can do it the actual elliptical design of the Zone1 &2 Sky Dish is ideal for multi-lnb setups rather that the A-typical Oval dish we all use
Thanks for the info, the problem is I cant run another cable Im not allowed, my dish, 1meter oval is now pointing to sky 28'e and we use it for sky, could I make an bracket and stick another LNB on and some sort of switch at the dish end to switch ??Sky Digital is at 28'e, RTL is on 19'e (which was the position we all used for analogue sky).
SSComment
Yes, a disque switch can be fitted at the dish end so you can use a single coax run.
SSComment
yes you can BUT a sly box cannot operate it so this may give you troubles if using a sly boxComment
