Help with sky box
  • scotspine
    • Mar 2012
    Help with sky box
    I have and old sky box that has just had a hiccup. The ITV region has went from STV to Central West is their any way to reset this? Thank you.
  • setfiretorain
    • Jul 2010
    • 934
    What you mean just went to it mate, you turn box off and when you turned back on it had moved or what ?
    Regards
    Sat Boxes
    Dreambox 500s.
    Dishes
    Sky minidish self fitted.
    • betas
      • 52
      make sure card is in a white one without card will give central as this is the default ch eg london
      • ramjet
        • 2995
        the card has a postcode on it to set the region of the box, so with no card it will default to london
        you can add the other itv channels in the other channels section of the menu but it wont default onto 103 without a postcoded card for your region
        • scotspine
          • Mar 2012
          Thank you for the replies.
          Setfiretorain, yes after switching off it just went to central, the card has rarley been out of the box, it is a white card
          • ramjet
            • 2995
            see if the box opens pick tv with the white card in
            if it does its working and the postcode on that card should still be set for your area and default the box to your local channels
            if it doesnt you will have to add the local channels yourself in "other channels"
            • bj1
              • 445
              are you subscribing? have you moved house?
              • scotspine
                • Mar 2012
                After reading your posts I switched off box took out card and cleaned it, lo and behold it worked. Thanks again you have helped this old one out
                • bj1
                  • 445
                  a quick reboot of the box is a common resolve to a lot
                  of probs with digital stbs
                  glad you got it sorted.....BJ1
