Using a monoblock lnb in a diseqc switch
  • seanmckeown
    • 206
    I have read on a lot of forums that you couldnt use a monoblock in a diseqc switch as the monoblock already uses its own switch internally.
    Finally i found a forum that said it was possible, and I tried it out and it works.
    If this is common knowledge then i'm just telling u things u already know, but this may benefit people who didnt think it was possible.
    The setup i was looking to combine into 1 single satellite output was:
    fixed dish at 28.2
    fixed dish at 13 and 19.2 with monoblock
    so the correct method of doing this is as follows:
    1. monoblock lnb feeds into the 'input' of a satellite or cable splitter (1 in, 2 out. must have dc pass on both sides)
    2, Create 2 small patch satellite leads, connect each of them to the 2 'outputs' on the splitter.
    3. On ur diseqc switch connect the 2 outputs from the splitter to lnb1 and lnb2
    4. Connect 28.2 fixed lnb to lnb 3
    5. Connect patch cable from output of diseqc to satellite box.
  • trevor1229
    • Oct 2011
    • 11
    I am going to attempt this Sunday, I bought all the bits so fingers crossed I can get it to work!
    • trevor1229
      • Oct 2011
      • 11
      Hi
      I have set it all up, but I can only get 2 sats to recieve. The monoblock has plit fine but cannot get any 28.2. If i put the cable from it straight into the box it works.
      Has anyone got any ideas what is wrong? Also what order should the Diseqc ports be?
      • seanmckeown
        • 206
        assuming ur 13 and 19.2 are in ports 1 and 2, then try 28.2 in either 3 or 4.
        should work no problem as long as u adjust the correct settings on ur box to correspond
        • trevor1229
          • Oct 2011
          • 11
          Yes 13 and 19 are in 1 and 2. I am putting bouquets on using Bouquet wizard and then selectin the ports on there.
          I have put the 28 in number 1 and it works by itself but not in any of the others.
          • trevor1229
            • Oct 2011
            • 11
            I think i have it now! On the bouquet wizard I put the Diseqc ports as 13=0 19=1 and 28=2. Where as before i didnt use the 0, just 1,2 and 3,
            Thanks for your help
            • Nutsandbolts
              • Oct 2011
              • 1168
              Hi. Is there is any reason why you did not put a motor on your dish? You would have got a lot more sats and channels and probably cheaper as well. Regards.
              • trevor1229
                • Oct 2011
                • 11
                Hi, well ive had an old dish up for about 10 years in which i had for old analogue satellite, then when it went digital I had a sky dish put up, but continued to use my old dish for german tv. I bought a monoblock a few months ago, so I only needed to run another cable from my sky dish and get a splitter and switch.
