Thinking of going to satellite.
  • Gazzaman68
    • 9
    Hi all i have a few questions regarding satellite,as i am new to this i need a few things explained.Having used starview in the past on cable,and still with virmin,i was thinking of changing .I live in a flat with a fixed shared dish,so not sure what my options are regarding box, channels etc.I presume i need an linux based boxwith this dish,any ideas what to go for,and what channels will i be able to recieve,and will they all be in foreign?Sorry about the long question but i am a bit confused what to expect from sat..thanks Gaz
  • lee11168
    • Feb 2011
    • 217
    openbox s10 is a good starter box
    • smokey_jnr
      • 380
      what box would you recommend that can handle 3D also..?
      • ramjet
        • 2995
        you will receive the channels on the satellite the dish is pointed at, which is probably 28.2 east and so you will receive freesat
        you dont receive "foreign channels" on that satellite
        any other channels on there needs a subscription of some sort
        • short360uk
          • 313
          Blade media 7000s i think is the only box on the market at minute that is 3D capable about ?150, easy to use too
          • joetwizzy
            • May 2011
            • 322
            all HD boxes are 3D
            • robbeno
              • Feb 2010
              • 389
              My dreambox isn't 3D ?
              • Shady
                Shite Link King
                • Dec 2010
                • 6404
                If its a HD dreambox it is,
                • digicon
                  • 8261
                  Depends which Dreambox it is if theres no HDMI output then yes your right its not 3D capable but if its a DM500HD or DM800HD, DM800HDse,DM7020HD,DM8000HD
                  did i miss any LOL
                  • mdt
                    • 3034
                    get yourself a vu+ duo clone and a solid friend and bobs your dads brother, regards mdt
                    • robbeno
                      • Feb 2010
                      • 389
                      Well I never!
                      It is a dm800hd but no 3D programmes in my ch list
                      • robbeno
                        • Feb 2010
                        • 389
                        Well I never!
                        Does it only come through when connected to a 3D tv ?
                        • digicon
                          • 8261
                          All the 3D channels natively show a picture which is side by side on a normal TV this is what it looks like
                          When used with the correct setting on a 3D TV the images are merged and so show the 3D effect
                          • robbeno
                            • Feb 2010
                            • 389
                            Yes I see just the 1 channel I have sky 3D
                            As you say split screen
                            Is the sub just the same or 3D on a diff sub
                            • Shady
                              Shite Link King
                              • Dec 2010
                              • 6404
                              Same sub, only one 3d channel on 28.2e and you have it
