Hi is anyone out there is having problem with up**rn. I have updated mine box with latest fw 1.19B1 but still no luck.
Utube and everything else is fine but when i connect to up**rn it say downloading andthen the network error. please help thanks
after about 30 minutes of viewing the box freezes for a few seconds with the message "scrambled", this repeatedly happens every 2 minutes, i have to then power the box off and then back on
after turning back on the box takes a few minutes for the premium channels to unlock, then after another 30 minutes the same problem begins
i have the latest software loaded on the box, downloaded via the menu section, plus u~~~~ is working
its not a server problem because i have tried a dreambox, blade and openbox and i do not get this problem
i have the same problem on all 3 units that i have purchased from satnet
Sorry to barge in and I know thread is a bit old but....
I'm looking 2 boxes one upstairs and one downstairs and was considering ordering a couple of these. Just wondering if any of you who own them are experiencing any problems with them? I know in one of the last posts someone was having freezing problems. I'm new to this sat thing (just turned off cable) and don't want to get stuck with two paperweights. I have considered ordering Skybox F3's also. Any advice welcomed!
I was one of the first ones to get this box and I have 2 set up and have not any problems with either of them so far.You will always get the occasional freeze,no matter what box you use.As mentioned in previous posts, The picture quality on these boxes is much better than the Openboxes and its variants.I hope this helps.
apart from having to reset the box every 30 minutes this box is perfect, my server is running on CCcam so maybe that might be the problem, but like i have said before other box's like the openbox, blade, etc work on my server with no problems what so ever
if i had to choose one box i would go for skybox f3, cheap but does the job fantastically well, just as good as the cryptobox
Geosuper,Have you tried leaving it on a free channel to see if it needs re-booting,just to eliminate server,connection etc.
