new Cas Studio 8.6c software 11/02/09
  • benny/9
    • 1964
    for the diablo cam and cas programmer users
    latest Cas Studio 8.6c
    Last time updated on 11/02/2009
    Gamma Card Programming problem solved
    you can download this new version from duolabs.com
    Please Read Carefully!
  • peratis
    • Oct 2008
    • kmssixyz
      • Mar 2009
      thanke very much
      • wooper
        • 460
        Silly question, but I dont need this if I only use underworld files???
        ta
        • aman23
          • Mar 2009
          • 8
          Help neede! Diablo cam seems not work
          Hello guys,
          Pardon me if I am still being dumb but for some reason I can't figure out how to make my diablo cam to work. I have a TM 6900 HD Combo Super and with the help of Benny I successfully programmed the Diablo cam (I hope!) I updated that with the Underworld 163, then 164. But when I put the CAM into the receiver and go to menu then Common Interface it always says "slot 1 and slot 2" instead of seeing the underworld files. What am I doing wrong? I am going crazy. Can you help me please?
          • benny/9
            • 1964
            Originally posted by aman23
            Hello guys,
            are you saying the cam is'nt recognised by the receiver
            and when you look in the common interface menu
            first is the cam fully pushed in the slot, and have
            you try turning the receiver off and on again then
            checking if it now shows. if you have and it's the same
            i would format the cam and load the latest 1.65 dup file
            put the cam in the receiver and see if it is now recognised
            if yes the re-set the cam configuration then your chns should open
            • aman23
              • Mar 2009
              • 8
              Thanks a million Benny I finally successeed! I gave up yesterday and just now I also realised that 8281 wouln't worked either. so I downloaded patch 671 and Alleluha! I was on board (I had 674 before). For some reason I needed to go back before my baby could respond to me. Great to have you around Benny!
              • benny/9
                • 1964
                it's good your sorted mate but the cam should work
                with any patch or without a patch mine works with all
                patch versions, when you say 8281 i take it you menu
                8280 for the entry of biss keys. if your cam is'nt working
                with all patches i think it's more likely you had a glitch when
                loading the patch, and loading a earlier patch cleared the problem
