S*y UK Channel List and Numbers
  • Bann32
    • Oct 2011
    • 518
    #16
    Merely out of interest, why doesn't the audio on the original work?
    • Rahat786786
      • Mar 2012
      • 15
      #17
      Not entirely sure either as the apid on both files is the same for the channels.
      • Rahat786786
        • Mar 2012
        • 15
        #18
        Updated with tweaks.
        • jaytag
          • 82
          #19
          open s11
          has anyone got good chanell list for open box s11 there prety messed up at moment thanks in advance
          • haniballs
            • Jun 2012
            • 9
            #20
            Is this working ok now? ie with sound on all the channels?
            • gaz31
              • Feb 2012
              • 32
              #21
              Yes mate the channel list is all working good now.
              • blade15
                • Jun 2012
                #22
                Anyone know the difference between this list and the one here Digital Kaos - Downloads - 28.2e Channel List for tm 5402/bm7000 14-05-12
                • gaz31
                  • Feb 2012
                  • 32
                  #23
                  Rahats channel list is numbered like the official sky guide. Don't think the other list is.
                  • blade15
                    • Jun 2012
                    #24
                    Could I get some help..
                    Basically, I have just put rahats sky list on the blade which works fine, however it is filled with blanks. (EG channels 1 to 100 are all blank an in the menu).
                    So when i delete these, it changes all the numbers of the channels, so like sky sports gets move to 300 when it should be 401.
                    Any solution for this anyone?
                    • christof21
                      • May 2012
                      I'm having trouble with the HD movie channels. The don't seem to show. When I try to do a manual search, I can't find the exact frequencies to scan for the channels.
                      Does it sound like my dish isn't set up properly?
                      • happy_highlander
                        • Aug 2010
                        • 3535
                        #26
                        What did you think would happen if you deleted the skipped channels, they are there to maintain the channel numbers and leave spaces for any new additions if you don't like the spaces try this list http://www.digital-kaos.co.uk/forums....php?p=1587265 it's a lot cleaner but doesn't use the sly numbers
                        • gaz31
                          • Feb 2012
                          • 32
                          #27
                          Since Rahat hasn't been around for a while i have updated his channel list with the latest transponder changes and updated
                          the new channel numbers.
                          This list is for Granada region.
                          • sootylfc
                            • Nov 2011
                            • 10
                            #28
                            Gaz
                            thanks for the update -
                            If someone shows or tells me how to update i dont mind doing it in the future.
                            Thanks again
                            • gaz31
                              • Feb 2012
                              • 32
                              #29
                              Updated channel list includes a few transponder changes, also includes BBC Olympic channels HD/SD.
                              • Markanddeb
                                • Jul 2012
                                • 30
                                #30
                                Do you think I could mess about with this and use in a spiderbox?
