S*y UK Channel List and Numbers
Updated to the latest transponder changes.Attached FilesComment
what do you need to do to change it so it works on tm800hd
and do you have to edit satellites.xmlComment
Only updated the Box Office channels, should all be in the correct order now.Attached FilesComment
Can I just point out gaz that this list is missing around 20 box office channels, like almost all other tm/blade lists. Don't know why it happens it just does. I'm sure a few days after my next update this list won't be missing the channels either. Which is fine by me.Comment
You will find the latest update dated 16/9 as 40+ Box Office channels, as i found there was a lot of dead BO Channels in the lists that have been uploaded on the site.The latest BO Channels were all manually done using lyngsat which i am thinking has the full list of channels??? compared to kingofsat which i usually use for updated transponders.Can I just point out gaz that this list is missing around 20 box office channels, like almost all other tm/blade lists. Don't know why it happens it just does. I'm sure a few days after my next update this list won't be missing the channels either. Which is fine by me.
Have no problem with people using this list any way they like as i am only keeping it up to date because the OP as disappeared.Last edited by gaz31; 18 September, 2012, 13:10.Comment
That's the list I checked m8 before I posted as I found the same thing and updated my channel list from lyngsat as well I just haven't uploaded it yet. I'll put it online when there are some more changes as box office isn't really that important and constantly changing channel lists are a pain in the erse for the users. I wasn't having a go about the list just giving you a heads up that I have manually installed all the box office on my list and your welcome to pinch them to save you having to do the same.You will find the latest update dated 16/9 as 40+ Box Office channels, as i found there was a lot of dead BO Channels in the lists that have been uploaded on the site.The latest BO Channels were all manually done using lyngsat which i am thinking has the full list of channels??? compared to kingofsat which i usually use for updated transponders.
Edit.....Just had another look at list and realized my mistake. you have added the extra channels but haven't added them to the ppv favorite which is all I looked in the first time.Last edited by happy_highlander; 18 September, 2012, 21:53.Comment
Sorry for not updating guys, I bought the Vu+ Duo and sold my Blade Box.
Keep up the good work gaz!Comment
