BM7000s Mar 14 2012 83x
  • irishbluestaffy
    • 611
    #16
    ye i did c it from ramjet so thanx ramjet i couldnt find the post it was on or my notepad i had it on,thanx to u both.
    • dadon123
      • 34
      #17
      Is anyone having problems with this new update? Since this update my box freezes still whilst watching. Happens on any channel. Remote doesn't respond, the buttons on the box do not respond, so I have to turn off the box via the switch at the back. I have done factory resets from the loader menu, reflashed countless times, still keep on getting this annoying problem.
      Anyone else experiencing this?
      • zee24
        • 3342
        #18
        na m8 mines been fine
        • bazsutto
          • Apr 2010
          • 10
          #19
          Yes,
          I got this the once so far. It was within 10mins of when I first patched it last night, but no further issues since.
          • zee24
            • 3342
            #20
            Originally posted by bazsutto
            Yes,
            come to think of it actually that happend to me when i patched it aswell thought it was only me but it was more like 2 mins for me, and been fine since.
            • irishbluestaffy
              • 611
              #21
              i had this with the jan patch but i never factory reset twice,no probs with this so far
              • dadon123
                • 34
                #22
                Wierdly enough, hasn't happened since I reported the issue. Touchwood it doesn't happen again Thanks for the responses anyway guys
                • leon632
                  • 129
                  #23
                  So has anyone found a use for the video share yet. It seems a waste of time to me at the minute. I can't see anyone parting with their money to set up a server to share their videos.
                  • bj1
                    • 445
                    #24
                    has anybody else having problems with router blocking
                    the blade as my netgear is.
                    everthing has been great untill today i have noticed my blade ip settings have changed and now cant get youtube if i try putting in original ip settings in it seems to be blocked.
                    anyone now how to solve this problem.
                    • dadon123
                      • 34
                      #25
                      Cannot comment on the router blocking problem as I have never experienced any of such issue, also I do not own a netgear router. As for the Videoshare, if you look hard enough, there are some servers out there (I havn't found any yet as I am not in need of it at the moment).
                      Unfortunately I continue to have the freezing problems I had reported before, so as a result have downgraded back to the stable version of the firmware (5th Jan). Had a look at other forums and a lot of people are complaining of this strange freeze issue with this new firmware. Seems like a memory issue to me.
                      If people have paid attention, this firmware is still in the BETA phase, so problems could be still around which will most probably be patched in the final version.
                      • leon632
                        • 129
                        #26
                        I also had to go back to Jan version. I'd go to work and when id get home my box had factory reset all by its self and my saved cndf files wouldn't load properly. Got fed up of failed recordings. Such a backward step since there last upgrade.
                        • roofer 247
                          • 29
                          #27
                          i heard if you put your blade box to DMZ in the router settings,you tube works.I also found 9992 gives you cam settings,great for putting new biss keys in.hope this helps.
                          • bj1
                            • 445
                            #28
                            seems like i am having same kind of problems with latest firmware and it is the only firmware i have used as i only had the box a couple of weeks i have tried putting in jan 5th firmware but when i try to download into box it comes up as invalid file..... has anybody got this firmware to send me so i can give it a try
                            thanks bj1
                            • bj1
                              • 445
                              #29
                              i put my ip into dmz of router connection was great untill the box changed to another ip address.
                              problem is if you set your ip to static it does not stay static if you have to turn your box off.
                              i also found that you tube works much better if you change audio settings to pcm.
                              ......bj1
                              • bazsutto
                                • Apr 2010
                                • 10
                                #30
                                I also have resorted back to Jan firmware fro freezing issue. I only get it on Sly Sports 1 HD for whatever reason. Hopefully resolved soon.
